saviour stivala
saviour stivala
52
‘Full energy recovery system (ERS). The re-deployed power (ERS) – Which harnesses energy produced by car on track, stores it, and then re-deploy that energy to create more power. This re-deployed power equates to 160bhp, which can be used for up to 33 seconds of a racing lap. The (ES) energy store – (the car’s battery). This energy store is where energy generated by the ERS is stored. Until it is needed for deployment, it can store up to 4 megajoules of energy for a lap. With this being the amount that can be redeployed in a lap.
sn809
sn809
sn809
sn809
Mattyw wrote:
17 Dec 2021, 18:00
You've got to assume RB will come out with the stronger PU having nicked a number of the merc engine staff this year
The development cycle means atleast one iteration of engineering will be needed for their input to count.
Most should be on gardening leave any way.
Skippon
Skippon
Mattyw wrote:
17 Dec 2021, 18:00
Why?? - you assume these were the most capable design leads at HPP. Perhaps they aren't and they left for RB as they had hit their glass ceiling....
dans79
267
Skippon wrote:
28 Dec 2021, 21:44
Mattyw wrote:
17 Dec 2021, 18:00
Not to mention from what I read when it first started happening, most of them weren't engineers but manufacturing people!
201 105 104 9 9 7
mkay
mkay
16
Mattyw wrote:
17 Dec 2021, 18:00
Some of the ex-Merc employees are still in their gardening leave though. Don’t expect their presence to be felt at RB until 2023 season at the earliest
siskue2005
70
mkay wrote:
29 Dec 2021, 23:41
Mattyw wrote:
17 Dec 2021, 18:00
By that time the PU will be locked in and they couldn't change anything major
rickybobbyf1
rickybobbyf1
Has mercedes hinted anything about the 22PU? I’ve been hearing a lot about progress in the red camp and H camp regarding their PU.
Marty_Y
Marty_Y
AeroDynamic
349
Regarding engines, it was said Mercedes’ improved engine weighed significantly more than the previous iteration through last season. I’m not sure if those reports were accurate or simply rumour.
So, I was hoping some knowledge-heads in this area could break down for us, what impact would a heavier engine have on set up / balance of a car? Does the car just simply go a bit slower due to the weight and no other impact, or does the weight distribution affect the balance and leave them having to rediscover / calibrate car balance further to adapt to the new weight?
kalinka
kalinka
Isn't engine CoG fixed (restricted heavily )? So it would just add weight but no change in CoG, so no effect in handling...unless the added weight is in the external components/cooling. If it's really much heavier it can affect optimal balance weight placement maybe. Could be I'm missing something though.
_cerber1
262
AeroDynamic wrote:
12 Jan 2022, 12:23
As far as I remember, the MB strengthened the fasteners and the places of the seals, which affected the weight towards its increase, but this was a forced measure to get through the season without problems.
I do not expect a repetition of similar problems in motors prepared for the 2022 season, and the weight will be the minimum allowed.
_cerber1
262
mclaren_mircea
mclaren_mircea
_cerber1 wrote:
19 Jan 2022, 13:56
If it is true they are going to have the engine advantage until 2025. Ferrari too managed to make the deficit and too improve the engine like Merceded but that means that the gap between the engine remains the same, and the Mercedes engine without reliability probles was more powerfull than the Ferrari one. What we here from Honda and Renault is not so optimistic. They didnt managed to make the gap compared to last year engines until to date. If all this rumours are true than there are massive news for Hamilton (if he does not retire) and Leclerc and Max is locked until 2026 with an inferior engine.
AeroDynamic
349
Some interesting insights about what’s going on with Mercedes engine.
Caveat- it’s translated from Italian
https://it.motorsport.com/f1/news/f1-me ... o/7414303/
The Stella enters the new era of ground-effect single-seaters with the awareness of counting on engine supremacy. The M13 E Performance power unit will feature a new supercharging system which is the result of the experience brought by a new German engineer. At the chassis level, however, there is some more doubt about the choice of the wheelbase that will be close to the 3,600 mm limit.
Mercedes has a certainty and a doubt. The doubt, of course, does not concern whether Lewis Hamilton will be in his place at the wheel of the W13 or not, given that the hepta-champion, despite the "wall of silence" erected after the contested final in Abu Dhabi, will be regularly in his place. .
The certainty concerns the new power unit that will be homologated before the Bahrain GP and which will represent the strength of the W13, the ground-effect single-seater that will be presented on February 18 in streaming.
Hywel Thomas, Chief Engineer at Brixworth, is deliberating a power unit that should represent a leap forward from last year's unit, the F1 M12 E Performance 6-cylinder. That engine had revealed weaknesses towards the end of its life, forcing the Mercedes engineers to shorten its duration (Lewis Hamiltion used 5 PUs in the 2021 season, and Valtteri Bottas even six, while the FIA ​​limit included a maximum of three in order not to finish in penalty).
With a shorter use (four GPs instead of eight) the Brixworth technicians took risks on reliability, pushing the engine mappings far beyond the limits they had set for the season, being able to draw on horsepower that had always remained in the engine availability, but they had never been touched for fear of breakage.
Evidently, not reaching premature aging, the engine could give its best, re-establishing an indisputable superiority over the still valid Honda engine that led Hamilton to be on par with Verstappen before the last Abu Dhabi GP.
In the standard configuration, the Mercedes power unit provided 1,026 horsepower, while the super-engine of the Brazilian GP in qualifying unleashed an additional 18 horsepower, that is to say a power of 1,044 horsepower thanks to an extreme map.
New German turbo specialist
The arrival of a German specialist in Brixworth would have allowed the development of a new turbocharger capable of enhancing the qualities of the 6-cylinder and hybrid recharging, allowing more extreme strategies, especially since the Petronas chemists, gasoline suppliers, they would have easily recovered the 20 horsepower lost in the first bench tests with E10 fuels, just as it should have happened to Ferrari with Shell. If the power unit is to be a staple in the world championship, there is some doubt about the W13.
