T-C, given your suggestion that the 'L-F' profile NPL/Hawker 'high-speed' wing employed
by the Tempest, as a major 'upgrade' over the Typhoon, was somehow of little value, since:
"...the big drag source isn't the wing."
Well, the fact that the Tempest was ~20mph faster at all power-settings, (as well as eliminating the
Typhoon's concerning aerodynamic 'buzz' vibration which caused fatigue to both airframe & pilot)
was an advantage - just as the Spiteful showed over the Spitfire - when both were otherwise
similarly powered, contradicts that particular assertion.. & this was true, even though the wing
area of the Tempest was increased over the Typhoon, & the Spiteful's decreased vs the Spitfire.
The Tempest was found (by more experienced Typhoon pilots than the USAAF chaps you noted)
to be similar in turning, but vastly improved in roll, over the Typhoon, esp' once spring-tab
ailerons were fitted to regular production machines.
Tactical trials of fighters undertaken in early 1944, prior to the Allied invasion of 'Festung Europa'
clearly showed the Tempest held a marked performance edge over all other machines at the low-
to-medium altitudes at which operational sorties in support of the invasion forces would be flown.
Monetary cost of Sabre production and Hawker airframes did not enter into consideration,
indeed rather, just as in F1, qualitative concerns were of greater importance for the projection
of air-superiority, in defence roles for ADGB (Fighter Command), & for 2nd TAF offensive ops.
Anyhow, a significant % of funds spent on British V12 production was squandered via R/R Merlin
by 'Butcher' Harris & his 'export-to-Germany' program via Bomber Command - plus as single-stage
supercharged engines for obsolescent fighters - useless for combat work against Nazi forces, such
as Hurricanes & Mk V Spitfires.
Nor were Mk IX/XVI Spitfires a match for Typhoons when pressed into 2nd TAF A2G work,
& Griffon Spits were not as effective as Tempests in tactical air-superiority roles,
just as the trials had predicted...
