Aston Martin AMR22
Re: Aston Martin AMR22
michl420 wrote:
10 Feb 2022, 18:51
That front wing adjusters on the inside will need two "enthusiastic" mechanic for a 2 sec pit stop. :lol:
The hinge design is also obviously designed to shed a vortex with that nice big triangle of metal sticking up in to the airflow at a slight angle to the stream.
siskue2005
70
Can they raise the wing central section more? So is there a minimum hieght?
bagajohny
bagajohny
Actual car at the launch event.
https://ibb.co/YddqxgW
Mat-tes
Mat-tes
30
F1NAC wrote:
10 Feb 2022, 18:50
Mat-tes wrote:
10 Feb 2022, 18:32
https://ibb.co/GW68Vg8
That is quite a sharp turn below the undercut, I wonder how much air they can turn with that sort of shape.
It's a bit hard to see on the limited set of pictures we have so far, but doesn't it look like a sort of opening where the diffusor steps up? Theres an odd joint/assembly there and I can't tell if there's a kind of Naka duct there or else, I guess not but it looks odd.
Isn't that usually position where they place IR cameras for monitoring the rears ?
I guess yeah that would make more sense, but why put it inside the floor exactly where the underbody surface needs to be the cleanest?
Really looks odd from another angle. Surely it's nothing but I really don't get why there's paneling+stuff happening there.
christian.falavena
AeroDynamic wrote:
10 Feb 2022, 16:51
Alt view of the rear + Brightened (Good res)
https://i.imgur.com/qWZm3iM.jpg
https://i.imgur.com/bU71diP.jpg
Looking the gap between the sidepod and the floor reminds me to this...Image
Maybe an attempt to double floor? Also Toro Rosso triet something similar in 2011 Image
OO7
OO7
171
Re: 2022 Aston Martin | Aramco | Cognizant F1 Team
37NoName wrote:
10 Feb 2022, 17:57
What purpose do the slits on the side pods serve?
Cooling exits for the radiators.
siskue2005
70
OO7 wrote:
10 Feb 2022, 19:11
37NoName wrote:
10 Feb 2022, 17:57
But in 2009 they said those caused turbulance and they banned it, but noe its back.
Does it really effect the car following?
Zynerji
110
JordanMugen wrote:
10 Feb 2022, 18:08
10 Feb 2022, 17:48
The tea tray is the most interest part to me. It has some holes going under the floor. Like a central vortex to prevent on side of the under-floor from influencing the other side?
Where did you find a photo of holes in the tea tray? There does seem to be a winglet on the splitter.
https://i.imgur.com/B3BtCf7.png
Not at that angle. Holes, or small tunnels directly behind it going under the centre of the car.
OO7
OO7
171
siskue2005 wrote:
10 Feb 2022, 19:25
OO7 wrote:
10 Feb 2022, 19:11
37NoName wrote:
10 Feb 2022, 17:57
I don't recall it being banned?
OO7
OO7
171
I foresee a lot of front wing damage after minor contact happening this season.
Gills were banned along with Chimneys.. but it was more for the chimneys why closed holes were banned in the side pods 50mm above the reference plane.
37NoName wrote:
10 Feb 2022, 17:57
A few things, for one, they can clean up the rear tire wake above the tire. Additionally, they allow you to run a tighter coke bottle and smaller cooling exit at the rear.
OO7
OO7
171
10 Feb 2022, 19:34
My mistake, for some reason I thought siskue2005 was talking about the undercut (Toro Rosso style) being banned.
