Aston Martin AMR22
siskue2005
70
Re: Aston Martin AMR22
FittingMechanics wrote:
11 Feb 2022, 17:03
siskue2005 wrote:
11 Feb 2022, 16:32
The front wing so much higher from the ground.
Will that be more inefficent to follow cars
This is all contradictory to the rules we had in the name of close following
The lower front wing, with a neutral section, the lourves on the side pods #-o
It was always meant to be that way. When you use ground effect tunnel you will get wings higher to let clean air in.
Thank you for the explanation.
If so then they could have raised the nose instead.
Like someone said above it looks too retro and generic for me
wowgr8
wowgr8
29
TimmTurbo wrote:
11 Feb 2022, 13:29
Andy Green said that The "new" design concept of the coolers is giving them the freedom to reshape the sidebods if necessary. It is to be expected that there is plenty of iterations during the season. In AMuS there is a new article which headlines "AMR22 with flexible concept"
Worth noting this team has significantly reworked the sidepod bodywork in or mid season in every season since 2019, not sure what that says about their design process in the winter
SmallSoldier
SmallSoldier
486
siskue2005 wrote:
11 Feb 2022, 16:32
The front wings are higher to help drive air to the tunnels, but they also look way higher than in the past because of the lack of rake, which pitched the front wings to the ground
Rodak
Rodak
37
It's certainly nice to see normal A-arm angles at the front. The larger wheels allow the upper upright connection to be high enough to get rid of the droop we've been seeing for so long. Pretty sure the suspension guys are happy to have a normal camber change on bump.
wowgr8
wowgr8
29
11 Feb 2022, 16:44
The cars look Okay... but just too retro for me though. I was looking at the space ships from 2008 and it just makes these look like Indycar or GP-2. Just me though. Maybe with development they will look more futuristic.
Totally agree on this. They took the old school look too far in some areas but if it brings about entertainment I'm willing to forgive the look
AeroDynamic
349
bosyber wrote:
11 Feb 2022, 17:35
AeroDynamic wrote:
11 Feb 2022, 15:20
I like the look of the new cars from this angle more
https://i.imgur.com/76kL2qm.png
As someone else pointed out on twitter, that lower picture shows a different front wing, with the main plane connecting to the nose (and thus being even higher in the middle).
I don't think so. it appears like that from the angle, but this photograph was taken of the car coming out, and the wing is consistent with the renders and the unveil yesterday:
it looks that way in the render too
jumpingfish
53
Feeling like cars gonna break their floors on curbs.. :?
FW17
171
Small flip up.........., are more allowed?
proteus
22
11 Feb 2022, 16:44
I hated the 08 cars. Gills, millions of wings and everything looking so fragile and cluttered. Sleekness is more pleasing to my eyes.
But i agree that this is becoming similar to Indycar. Getting bigger and heavier is also not helping.
bosyber
bosyber
45
AeroDynamic wrote:
11 Feb 2022, 17:46
bosyber wrote:
11 Feb 2022, 17:35
AeroDynamic wrote:
11 Feb 2022, 15:20
https://i.imgur.com/yYhZMeg.png
https://assets.astonmartinf1.com/public ... F_sRGB.jpg
Yeah, sorry, I just edited my post, I think you are probably right that it's just the angle; on most launch pics of the real car we saw it from above, and that front profile clearly is turned up as far as possible to help air get under the nose as much as possible too, which enhances the effect.
WaikeCU
proteus wrote:
11 Feb 2022, 17:50
11 Feb 2022, 16:44
Was just going to say looking from the front, it kinda makes me think of older Indycars
jumpingfish wrote:
11 Feb 2022, 17:46
https://twitter.com/ScarbsTech/status/1 ... 3181427712
F1 designers will have to learn a thing or two from the VW iDR pike's peak. It had skirts but the skirts were very tough, almost flexible so it could rumble over a few rocks every now and then.
Shakeman
33
FW17 wrote:
11 Feb 2022, 17:49
A reflection not a 'flip up.'
F1Krof
95
jumpingfish wrote:
11 Feb 2022, 17:46
... agree with Scarbs and totally makes sense until we see Red Bull with their ass lifted up high! :lol: :lol:
Wroom wroom
siskue2005
70
jumpingfish wrote:
11 Feb 2022, 17:46
So, this season onwards low rake is the better solution? But i read somewhere high rake can also work...any thoughts
