2022 Alpine F1 Team
PowerandtheGlory
PowerandtheGlory
Re: 2022 Alpine F1 Team
With Williams going for an All blue colour, I guess it means alpine will be pink..
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
Redragon
19
I would be nice to see it painted with double tone color. That mix the pink and blue depending on the light
Jolle
Jolle
133
Pink, blue, red and white? bit like yellow, orange, red and white of the ING Renault... not the best choices to combine
Not that I'm any good at this but maybe something like one of these 2 pallets
stan_french
stan_french
second one seems more likely to me, but it would look great!
Herr_Koos
PowerandtheGlory wrote:
15 Feb 2022, 23:26
Alpine will not have based their livery design on what Williams decided to do. How would they have known ahead of time anyway?
Besides, it's not like you can't have only one team running a particular colour.
PowerandtheGlory
PowerandtheGlory
I’m trying to remember but I’m sure the FIA introduced a rule that teams can’t have similar colours. And any colour change must be approved. So I’m sure Williams have gone mainly blue.. because alpine are mainly pink…
Rodak
Rodak
35
If your manufacturing materials allow you to run the engine hotter (>140°C) you can use less airflow restrictive radiators, and / or smaller radiators, added to a superior thermal efficiency derived from lesser losses to the cylinders walls and the combustion chamber, because of the reduced delta of temperature.
All very well, but the maximum pressure of the coolant system is 3.75 bar per Technical Regulations:
7.4 Coolant header tanks
Any header tank used on the car with a water based coolant must be fitted with an FIA
approved pressure relief valve which is set to a maximum of 3.75 bar gauge pressure, details
of the relief valve may be found in the Appendix to the Technical Regulations. If the car is not
fitted with a header tank, an alternative position must be approved by the FIA.
Zynerji
110
Rodak wrote:
17 Feb 2022, 03:28
So, you can avoid all of that by using a glycol based coolant? 🤔
Herr_Koos
17 Feb 2022, 00:31
Would love to see that rule. If true it's not a bad idea. Last year the Merc, Aston, and Alpha Tauri looked identical front on.
Having said that, I'm willing to put money on the fact that the Alpine will contain a fair amount of blue because a) it's their signature colour, and b) the team has a strong French identity which was reinforced by last year's livery. They will find a way to incorporate the pink into their brand, not just paint the whole car with it like Force India did.
Jolle
Jolle
133
17 Feb 2022, 00:31
As F1 is basically racing billboards, I don't think this is much of an issue. Teams race to be noticed, they need to stand out from the other nine on the grid. You don't do this to be "one of the blue cars", so, they try to pick a livery that sets them apart from the rest of the field.
Unless you're Williams of course, who have some weird love for blandness over the past few years.
A13EX_f
A13EX_f
Redragon wrote:
15 Feb 2022, 23:41
https://previews.123rf.com/images/deuse ... pt-car.jpg
The problem with this type of paint is that it requires many layers for it to work, teams won't want to put that much weight high up on the car if they don't have to. IIRC Mclaren dropped the chrome paint due to it's extra weight.
SmallSoldier
SmallSoldier
479
New Team Principal!
F1NAC
169
Pretends to be shocked
JPower
JPower
43
Probably one of the worst kept rumors ever. lol
