![Image](https://i.imgur.com/n6nG8jd.jpg)
Only single bib unlike AM
Maybe they will add it later?
Or maybe they don’t need it.siskue2005 wrote: ↑18 Feb 2022, 20:11https://i.imgur.com/n6nG8jd.jpg
What do you mean?Hoffman900 wrote: ↑18 Feb 2022, 18:31This was always going to happen with underbody tunnels, and this goes back 30 years now.
I believed it up until the "evade blue shell!" at the point I knew you were talking s##t
Lol you saying Mercedes are lying ?.. its close enough to the real thing
The rendered image on the tweet you quoted is far from the actual car.Henri wrote: ↑18 Feb 2022, 20:40Lol you saying Mercedes are lying ?.. its close enough to the real thing
The render looks significantly different.Henri wrote: ↑18 Feb 2022, 20:40Lol you saying Mercedes are lying ?.. its close enough to the real thing
The sidepods of the real W13 are far more forward than in the render, that's one pretty significant difference.Henri wrote: ↑18 Feb 2022, 20:40Lol you saying Mercedes are lying ?.. its close enough to the real thing
I can't take that article seriously when he uses the render which positions sidepods well behind the mirrors! Real car has mirrors connected to the side pods. In fact, if you look at it right, Ferrari also has mirrors at the start of their sidepods like Mercedes. Silly stuff. Not to mention that Ferrari seems to have a "bulge" at the front of the sidepods and the real sidepod starts behind while Mercedes (on a real car) doesn't show this type of a bulge. It could mean Ferrari mounted engine further back than that.timoth wrote: ↑18 Feb 2022, 20:03https://www.formula1.com/en/latest/arti ... 9tPtR.html
The part about PU positioning (Merc vs Ferrari) is very interesting. Merc has pushed PU as backward as possible, while Ferrari has pushed PU as forward as possible. There were rumors that with the understeer-y nature of new cars, RedBull was trying to put PU forward and immediately behind the cockpit. We haven't seen RedBull yet, but Ferrari clearly has done this.
It seems that in terms of weight distribution and Center of Gravity, this PU placement has helped Ferrari, but Merc on the other hand has much slimmer sidepods thanks to pushing PU backward and using more centerline cooling.
I wonder which solution will be more effective with the new cars?!!
