Red Bull RB18
Owen.C93
Owen.C93
177
Re: Red Bull RB18
ringo wrote:
07 Mar 2022, 19:10
Any images of the oil tank?
Thats an interesting area and it makes sense to have the weight down there.
07 Mar 2022, 19:11
Just_a_fan wrote:
07 Mar 2022, 15:18
ringo wrote:
07 Mar 2022, 14:31
right it was the Hass. But looking on that slot at the front and the different panels.. I would suspect a spring and damper maybe in there. The car will ride on that keel quite often. The slot may have sensors or camera or it may be to allow adjustment.
Red Bull run their oil tank in this location and the slot is probably just a sight-glass to enable that to be assessed.
Which oil tank? Hot engine oil nestled away under the driver's bum? Where is the vent? Sounds like disaster waiting to happen.
Double-check and confirm this.
RB16B and AT have it here.
Re: Red Bull RB18
Owen.C93 wrote:
08 Mar 2022, 15:30
ringo wrote:
07 Mar 2022, 19:10
07 Mar 2022, 19:11
Just_a_fan wrote:
07 Mar 2022, 15:18
https://cdn-1.motorsport.com/images/mgl ... tion-1.jpg
I have seen this claim before but no engineer has confirmed whats inside it.
"Auxilliary oil" Scarbs says. Then Matt Sommerfield repeats.
One tiny line comes in at the top. Im not sure if it has a return line from the photos. It could be also a pneumatic tank... Just never seen this thing confirmed.
dans79
267
Re: Red Bull RB18
08 Mar 2022, 15:48
where are people seeing a tank?
201 105 104 9 9 7
Chubbs
Re: Red Bull RB18
dans79 wrote:
08 Mar 2022, 18:08
08 Mar 2022, 15:48
"its what looks like a carbon handbag hanging above the T-tray"
Chubbs
Owen.C93
Owen.C93
177
Re: Red Bull RB18
08 Mar 2022, 15:48
https://twitter.com/ScarbsTech/status/1 ... 4333371399
Well it's rare anything in F1 is confirmed by the teams. But regardless they have that module there in recent years so it stands to reason it's still there in their new splitter design.
dans79
267
Re: Red Bull RB18
Owen.C93 wrote:
08 Mar 2022, 18:28
08 Mar 2022, 15:48
It's probably a "hydraulic oil" overflow or something similar.
201 105 104 9 9 7
vorticism
323
Re: Red Bull RB18
It's mounted like a pendulum... For a reason?
𓄀
Re: Red Bull RB18
Translated by DeepL:
Red Bull RB18 with rear pushrod suspension and central ventilation
Henk_v
Henk_v
86
Re: Red Bull RB18
I ve been looking at this perforated plate on the radiator. It makes little sense to me.
Is it there to simulate less cooling for testing?
Re: Red Bull RB18
Henk_v wrote:
08 Mar 2022, 21:40
It's a way to adjust the cooling. Think of the tape on the nose of a Nascar. More tape, less drag.
vorticism
323
Re: Red Bull RB18
It's a grate way to do it, tbh
Regarding the longbow, looks like RB15 had it too, or something like it:
Anyone have high res? In this application it's as though it was used to maximize the s-duct port.
𓄀
Re: Red Bull RB18
vorticism wrote:
08 Mar 2022, 19:42
Theoretically they could use it like a mass damper.
230
Re: Red Bull RB18
Looking on the space underneath the Rb18 side pods. Could that unpainted panel be replaced by dive planes that meet the minimum radius regulations? or would this violate a rule regarding how many closed cross sections are permitted? I havent read tech regs in years.
But if something wild were to be on the car it would be placing winglets in that open space.
djones
djones
Re: Red Bull RB18
Are there any fancy changes like Mercedes, or is the car looking similar to the last test?
loekf2
loekf2
Re: Red Bull RB18
djones wrote:
10 Mar 2022, 09:38
Looks very similar. Same sidepods, same beam wing & diffuser.
Hard to see if they made changes to the undercut & floor. In Barcelona it looked unfinished.
