Mercedes W13
dialtone
dialtone
121
Re: Mercedes W13
NathanOlder wrote:
10 Mar 2022, 10:10
Looked like the porpoising has been fixed, just saw the car on straight and didnt seem to be doing it with the small rod attatched to the edge of the floor
Last lap they showed Lewis was going back in the box slowly so I wouldn't expect porpoising to be there then. It improved a bit but still jumping around quite a bit and unstable out of slow corners.
dans79
267
Re: Mercedes W13
dialtone wrote:
10 Mar 2022, 10:16
NathanOlder wrote:
10 Mar 2022, 10:10
A lot of the cars have looked tail happy. A portion of that is probably because the track is green, and teams are still working on setup.
201 105 104 9 9 7
AeroDynamic
349
Re: Mercedes W13
The mercedes centre-line packaging has got bulkier per the comparison.
The sidepods are further back for sure via the comparison
DChemTech
DChemTech
44
Re: Mercedes W13
I guess one could say that Mercedes has strongly reduced the gray area in their design :mrgreen:
Re: Mercedes W13
10 Mar 2022, 10:08
I think what they achieved here is to reduce the impact of the upper wake as Kyle engineers would say ans also that side pod lift should be elimianted.
The side pod at it's widest is not all that narrow. You can still see the lower crash structure is not protruding. But you can bet that the draggiest parts of the side pod are no more.
She should rely fly down the straights that's for sure. I'm worried about reliability and balance.
The more I'm looking at this design, the more problematic it seems. The aerofoil around the side impact structure looks massive, angled and decently cambered - that's a lot of lift and drag just with that one element. However, this would also draw a bit more air to the rear and beam wings. I'm sure the team wouldn't make this kind of effort if it wasn't worth it in the end, but there are a lot of compromises and they don't look that small to me.
Worth noting, I really like the design diversity with these new regulations. Wasn't expecting it at all.
dans79
267
Re: Mercedes W13
It's interesting, that they ran a few laps with the front lovers taped over. Almost to say look we don't need them!
I wonder what Horner will think of that.
201 105 104 9 9 7
mzivtins
mzivtins
Re: Mercedes W13
Vanja #66 wrote:
10 Mar 2022, 10:24
10 Mar 2022, 10:08
Could this be the emrgeance of two philosophies, one seeks to reduce or eliminate side pod lift (Ferrari) the other is to work as sealing the floor the increase its effectiveness to forcefully overcome and lift issue around the Centre of the car (McLaren & Mercedes)???
maxxer
maxxer
Re: Mercedes W13
AeroDynamic wrote:
10 Mar 2022, 10:21
Yeah noticed that 2 from behind the halo its flat now
AeroDynamic
349
Re: Mercedes W13
The bulkier body beneath the Ineos Logo.
Receded sidepod profile, closer to headrest.
levidrugi
levidrugi
Re: Mercedes W13
AeroDynamic
349
Re: Mercedes W13
Re: Mercedes W13
Stiff, but no porpoising on that last lap with VET behind.
Re: Mercedes W13
mzivtins wrote:
10 Mar 2022, 10:26
Actually, all 3 cars have 3 very different aero philosophies. And then there's RB/AT as 4, Williams as 5 and other teams as 6.
GrizzleBoy
GrizzleBoy
33
Re: Mercedes W13
Car looks like a maaaaassive handful. Lewis was trying to stay ahead of vettel just now and the car wouldn't turn in the slow corners and just drifted into the runoff.
Usual caveats of no idea of fuel loads and run programs etc.
InsaneX_Badger
Re: Mercedes W13
Car does seem a real handful, struggling to turn in and put the power down coming out
