GP AUSTRALIA
1.Differnt front wheel rim shields
2.Different sidepods
3.Shorter exhausts
4.Different rear wing
FRONT WING
1.Double profiled front wing
2.The second profile is the movable one , adjustable by the driver through a range of six degrees.
3.The central part of the wing is standardized by FIA regulations
4.Very curvy endplates to direct air to the outside of the front wheel
5.Extra element to further divert airflow away from the front wheels to reduce drag .
6.There is an additional triangular fin attached on the rearmost upper edge of the endplate
7.The outer extremities are bending slightly upwards to create a gap between the wing profile and the ground in order to reduce the pitch sensitivity of the car at high speed
8.There are deep, rounded cuts at the outer extremities of the rearmost flap .These help reduce drag on the very long straight before the final corner.
9.Venturi Channel
