Red Bull RB18
Re: Red Bull RB18
Car is very overweight. More laptime to come if they can put it on a diet. Less Red Bull, more protein shakes.
A lion must kill its prey.
Airshifter
Re: Red Bull RB18
20 Mar 2022, 01:10
Does anyone have any actual evidence of this or is it just continued rumor/speculation? I keep seeing a lot of the latter but no numbers.....
dialtone
dialtone
123
Re: Red Bull RB18
Airshifter wrote:
20 Mar 2022, 01:12
20 Mar 2022, 01:10
I thought one rumor from last night was that RBR had shaved off 7-10kg off the car since the last test in Bahrain, then someone started saying they were 20kg overweight here before so now they are 10kg. It does feel like the numbers are bouncing around on RBR weight.
Re: Red Bull RB18
This new rear wing seem to have slipped by...
The spoon starts off early and is more aggressive and there's a curvature in the outer edges.
For comparison, less spoon and flat outer edges.
Looks lower downforce to me.
vorticism
323
Re: Red Bull RB18
𓄀
Stu
Re: Red Bull RB18
There are a couple of strange looking scoops in there, next to the chassis. They look like air inlets?
Also very interesting detailing of the strakes!
restless
restless
Re: Red Bull RB18
Given how massively RB is losing in braking zones to Ferrari, shaving 5-10kg can give good plus simply by improving braking dynamic
teemah
teemah
Re: Red Bull RB18
If you’ve not read it, definitely worth a read, Mark Hughes provides a detailed account and analysis comparing Leclerc’s and Verstappen’s Bahrain Q3 laps.
https://the-race.com/formula-1/mark-hug ... d-red-bull
Ashwinv16
Re: Red Bull RB18
So the two retirements within a lap of each other. Seems like Hydraulics overcooled did'nt it due to too much air into the radiators causing battery and gearbox overheating after fliuds stopped flowing pretty much. Anyone with previous motorsport experience can confirm this.
Halo not as bad as we thought
232
Re: Red Bull RB18
dren wrote:
23 Feb 2022, 22:17
Hoffman900 wrote:
23 Feb 2022, 20:49
ringo wrote:
23 Feb 2022, 20:47
Redbull has a risk of overheating. The area under the oracle logo will be fried quite often.
They are pushing the limits for sure. Normally the radiator is tilted forward in the sidepods, with the sidepod having reasonable volume for other equipment and for hot air to flow around and out.
This design is as if all the equipment was crammed together then they scalloped that volume that's normally before the radiators.
Fastest car on the grid for sure, based on the floor, the floor vortex generator end plates, the sidepod wing, the undercut, the beam wing, the diffuser, the rear brake ducts... But most reliable and driveable? I think that is the bigger mystery with this machine.
The Mercedes car appears more conservative, but it has equally small sidepods, but most of all the design seems more robust and it just appears to be less aero sensitive.
This indeed is a very extreme and precise design. Nothing was spared. Even the front wheel hub and pull rods are extremely clean and light and low drag.
Without trying to sound facetious, what experience are you basing your opinion on?
It's all based on the ellipse.
:lol: :lol: What's that?
Car is clearly unreliable. So is Alpha Tauri. Systems packaging could be too tight. Maybe with moving the electronics outside of the side pods, they do'nt get as much cooling as they need?
NtsParadize
NtsParadize
Re: Red Bull RB18
According to Red Bull it could be a fuel pump issue on both cars. Interesting since the fuel pump is now an FIA standard part.
Envoyé de mon Nokia 8.1 en utilisant Tapatalk
vorticism
323
Re: Red Bull RB18
RB combine flexures with multilink on the front axle, so steering force is acting against suspension arm spring force to some degree. Whether or not this could have contributed to today's steering issues, I don't know.
Reason: Removed personal comments
𓄀
Re: Red Bull RB18
NtsParadize wrote:
20 Mar 2022, 19:33
I suspect it might have overheated when the tank was no longer full of fuel to cool it.
chrisc90
Re: Red Bull RB18
NtsParadize wrote:
20 Mar 2022, 19:33
Wonder if there will be other pump failures on other cars. Wasnt Charles saying he had issues on last lap? (from what someone posted on here)
chrisc90
Re: Red Bull RB18
20 Mar 2022, 19:46
NtsParadize wrote:
20 Mar 2022, 19:33
Wonder if the FIA will step in and sort issues with pumps.
