Mercedes W13
Re: Mercedes W13
Something else got me thinking.
Sauber has made their own rear gearbox, but are the suspension components theirs or Ferraris? Hard to believe a Sauber suspension is more advanced than a Mercedes one? Just pondering how much weight must be put to suspension as the root cause.
matteosc
matteosc
30
Re: Mercedes W13
Interesting video, hinting at what said before in the thread.
https://www.youtube.com/watch?v=2s14kQ4f5gA
I still think the problem is not all suspension, but it looks like it is no "simply" underfloor stalling.
SirBastianVettel
SirBastianVettel
Re: Mercedes W13
PlatinumZealot wrote: ↑
29 Mar 2022, 19:27
In the SA Tech Talk episode on F1TV there was an interview with Jan Monchaux from Sauber and they said they don't use the Ferrari rear suspension.
NicoS
-2
Re: Mercedes W13
how easy would it be for MercedesAMG to copy Ferrari or RB aero solution?
dialtone
dialtone
123
Re: Mercedes W13
NicoS wrote: ↑
29 Mar 2022, 20:11
It's not about how easy it is, it's about how much it will cost, in a budget cap. Once they copy they kind of set themselves behind a bit since they need to start learning the new concept and develop it going forward while they already spent all of the money on the existing.
Obviously if their concept is just bad, copying is the better way, at least to avoid the sunk cost fallacy, but probably they don't know yet and still believe in what they've done.
NicoS
-2
Re: Mercedes W13
dialtone wrote: ↑
29 Mar 2022, 20:16
NicoS wrote: ↑
29 Mar 2022, 20:11
how long would be feasible to continue with this package before they consider copying another solution.
Do you think mid season would be a good time to re-focus on a new approach?
carisi2k
27
Re: Mercedes W13
I think Mercedes need to drop the zero pod and bring back the solution they had at Barcelona if they want to be faster. It looked like it was a faster solution as it seems to be able to do something that the zero pod isn't able to. Even the other small sidepod solution is struggling in the Williams although the power unit might also be causing Mercedes teams to struggle as well. I'm enjoying watching Mercedes struggle and especially seeing Bottas doing well in the Alfa.
algebraist
algebraist
Re: Mercedes W13
NicoS wrote: ↑
29 Mar 2022, 20:24
dialtone wrote: ↑
29 Mar 2022, 20:16
NicoS wrote: ↑
29 Mar 2022, 20:11
Oh FFS get the idea of copying other people's work out of your head. Aston Martin tried that the other year and look how well it worked out for them. It's not enough to simply copy, you must also understand wtf it's doing and behaving as well.
You're also talking about repackaging the entire innards of the car as well. It's a totally impractical idea especially in these years of cost capping and cutting. Whether you like it or not, this is what they're running this year and likely next. Once they sort out the floor / suspension issue, the rest will follow.
vorticism
323
Re: Mercedes W13
Why did they test two types of sidepod? Just to have something to compare against?
π“„€
mkay
mkay
16
Re: Mercedes W13
algebraist wrote: ↑
29 Mar 2022, 21:21
NicoS wrote: ↑
29 Mar 2022, 20:24
dialtone wrote: ↑
29 Mar 2022, 20:16
They don't need to repackage the innards given they've got the tightest innards already; they can simply design bodywork around the existing innards.
dans79
267
Re: Mercedes W13
vorticism wrote: ↑
29 Mar 2022, 21:22
In Barcelona they ran an early revision of the w13 that was most likely finalized last year, maybe even before the season was over. What they ran in Bahrain was a later revision, most likely finished as late as possible.
201 105 104 9 9 7
Re: Mercedes W13
mkay wrote: ↑
29 Mar 2022, 21:51
algebraist wrote: ↑
29 Mar 2022, 21:21
NicoS wrote: ↑
29 Mar 2022, 20:24
But it would still be an unoptimized package because they'll have an unnecessarily high CoG.
algebraist
algebraist
Re: Mercedes W13
Precisely this. Copying a car is more than just the shell.
Aesop
Aesop
Re: Mercedes W13
NicoS wrote: ↑
29 Mar 2022, 20:24
dialtone wrote: ↑
29 Mar 2022, 20:16
NicoS wrote: ↑
29 Mar 2022, 20:11
As long as Mercedes believes their concept has more potential than others and think they can solve the issues they will continue developing. There comes a time Mercedes will acknowledge this season is lost, but as long as they feel they will reap the benefits next year there is no incentive to think of other concepts.
Re: Mercedes W13
The big diffuser and edge wing like on the Mercedes with no sidepods to share the load, means the floor has more load to take than something like a Ferrari, or Alpine. That means the floor is more prone to deformation and flexing. More deformation and flexing means more vortex shedding unless you make the floor stronger. If you make it stronger then it's also heavier.
