Red Bull RB18
Re: Red Bull RB18
Has the new rear wing been posted?
A lion must kill its prey.
Re: Red Bull RB18
07 Apr 2022, 18:14
This isn't it?
Re: Red Bull RB18
ringo wrote:
07 Apr 2022, 18:07
NicoS wrote:
07 Apr 2022, 15:42
This car is an absolute jewel!
From these pictures, I get the feeling that they are blowing the diffuser with the flank of the sidepod and the tyre squirt area.
They are basically ramming air into that tight space, almost like a nozzle effect. They should get more suction from the diffuser, but critically, they have a better pressure gradient between the front and back of the car to mitigate against choking.
Exactly! The venturi effect works by shooting a jet of air into a diffuser, the air from the jet turbulently mixes with the diffuser and effectively pushes the air out of the diffuser. In doing so, it draws in more air through the inlet, which then accelerates through the throat, which shoots into the diffuser as a jet of air, turbulently mixing and pushing the air in the diffuser out.
This is why no diffuser has perfect pressure recovery, there's always a small pressure loss. And why reducing the back pressure in the diffuser/outlet increases flow velocity, as it increases the mass flow everywhere in the pipe. Even when the flow is choked, you can further reduce the back pressure after the throat, which will result in an increase in flow velocity via Prandtl expansion fans.
Re: Red Bull RB18
godlameroso wrote:
07 Apr 2022, 19:10
07 Apr 2022, 18:14
https://pbs.twimg.com/media/FPvR4_KaQAM ... name=large
This isn't it?
Maybe?
Is it different to these ones? Looks similar:
https://cdn-1.motorsport.com/images/mgl ... ing-1.webp
dxpetrov
dxpetrov
-7
Re: Red Bull RB18
No, it the same as in KSA.
Andi76
Andi76
446
Re: Red Bull RB18
Craig Scarborough just posted a rear suspension layout, probably similar to the RB18s. He adds that RBR reaction bar may has his own spring as it has a linear sensor mounted to it, creating a dual rate heave spring effect.
Re: Red Bull RB18
https://www.motorsport.com/f1/news/f1-a ... s/9691595/
Australian GP: Latest F1 technical developments from pitlane
Join us as we explain the latest technical updates being showcased in the pitlane as teams prepare for the Australian Grand Prix,
courtesy of Giorgio Piola and Sutton Images.
A higher downforce rear wing configuration is available to Red Bull this weekend, complete with a Gurney flap
on the trailing edge of the upper flap.
Top-down overview of the very sinuous front wing on the Red Bull RB18, also note how the endplates
have gentle outward curvature.
Re: Red Bull RB18
07 Apr 2022, 21:17
https://cdn-6.motorsport.com/images/mgl ... wing-1.jpg
https://cdn-6.motorsport.com/images/mgl ... and--1.jpg
The lower element looks like a half-way solution between Bahrain and Jeddah, also the end plate has a little curve on the leading edge where the "o" in Esso is at.
Re: Red Bull RB18
New fw endplates
silver
silver
Re: Red Bull RB18
dxpetrov
dxpetrov
-7
Re: Red Bull RB18
Again "expert hawk eyes" saw nonexistent new parts and MSM took information on face value and spread disinformation. Somehow sounds familiar in a global sense.
Re: Red Bull RB18
Andi76 wrote:
07 Apr 2022, 20:42
There is some similarity in the upper rocker design to the Mercedes Project 1 hypercar
The horizontal spring controls heave stiffness. The diagonal spring controls corner stiffness via 2 different springs along the same shaft. Each reacting independently to the different wheel corners. Quite clever actually. There's a youtube video from Kyle explaining it.
I know that Craig is not claiming he drew the RB suspension, but I think there is still some differences in implementation to what crew has drawn. Particularly relating to the corner damper at the top, and the linkages at the spring that is at the bottom that he calls the "reaction link". I think the right side is fixed based on the pictures from the RB.
Andi76
Andi76
446
Re: Red Bull RB18
08 Apr 2022, 06:34
Andi76 wrote:
07 Apr 2022, 20:42
https://car-images.bauersecure.com/page ... scale=down
Always expected the teams to go for a conventional suspension with two vertical dampers and horizontal torsion bars pivoting on vertical rockers and a third damper, similar to this one :
https://www.scaleautofactory.com/mgpf39 ... nsion2.jpg
Re: Red Bull RB18
Also, I'm getting confused between Craig's drawing and the actual RB rear end. The detail at the bottom looks completely different:
Andi76
Andi76
446
Re: Red Bull RB18
08 Apr 2022, 07:07
https://i.postimg.cc/hG0M0rPy/Image-3.jpg
Completely agree, i was confused, too. I missed a third element (damper or heave spring) on top. I expected two vertical dampers and a third element(heave spring) on top.
