Are they not allowed to make those adjustments in Parc Ferm if a wet race is called?Mattchu wrote: ↑18 Apr 2022, 14:36It will be very intersting if it does turn out to be wet in parts of the weekend. Ground effect is the same (pretty much) whether the surface is wet or dry surely?
Some cars may sort of gamble that wet tyres are going to be mainly used so will drop the car by the 5mm height mentioned, this could cause "issues" if slicks are used, others may keep it at the same height they`ve been using and take any hit which wet tyres and the resulting height changes bring!
Although it probably won`t make much difference in the end, save for a few outliers!
Pretty sure they`re only allowed to change things like brake ducts, radiator ducts and tyres but can`t mess with suspension components or lower the ride height...Big Tea wrote: ↑18 Apr 2022, 18:14Are they not allowed to make those adjustments in Parc Ferm if a wet race is called?Mattchu wrote: ↑18 Apr 2022, 14:36It will be very intersting if it does turn out to be wet in parts of the weekend. Ground effect is the same (pretty much) whether the surface is wet or dry surely?
Mattchu wrote: ↑18 Apr 2022, 19:54Pretty sure they`re only allowed to change things like brake ducts, radiator ducts and tyres but can`t mess with suspension components or lower the ride height...Big Tea wrote: ↑18 Apr 2022, 18:14Are they not allowed to make those adjustments in Parc Ferm if a wet race is called?Mattchu wrote: ↑18 Apr 2022, 14:36It will be very intersting if it does turn out to be wet in parts of the weekend. Ground effect is the same (pretty much) whether the surface is wet or dry surely?
While i can follow your reasoning, there is also the aspect of turning on the rain tires and getting those in the right temp range. This might be even more important, and is largely an unknown. Maybe the RB puts more energy in there based on last race?JPBD1990 wrote: ↑18 Apr 2022, 05:46Rain looking like a possibility this weekend. Given where Ferrari seem strong - low to medium speed and under traction, a layman has to assume rain would play to their strengths.
I also have to assume it would help merc who, at least in race trim, seem to have similar strengths to the Ferrari. Rain would slow them down a bit maybe making porpoising less of an issue?
Redbull with an understeery balance and favouring low-load wings and high top speeds, one assumes, would struggle…
But that’s just my best guess. Can’t wait to watch it unfold. Even as an Aussie who just got to watch his favourite team dominate in aus, I’m happy that f1 is back in Europe and some order can be restored to my sleep schedule.
Not only that´s illogical but it will be inconsistent too. Before, people that were quickest on qualifying but did not start the GP on pole, were not given the "pole statistic"(for instance, Schumacher on 2012 or Leclerc last year, at Monaco), but now they willerudite450 wrote: ↑17 Apr 2022, 15:16How does that work exactly? "Well done. You are credited with pole but you won't start on pole."MtthsMlw wrote: ↑17 Apr 2022, 12:47Yes, sprint still sets the grid for the race.BlueCheetah66 wrote: ↑17 Apr 2022, 12:10Does the winner of the sprint still start first on Sunday? When they first said that the pole was awarded in the qualifying I was confused
I couldn't agree more!Artur Craft wrote: ↑19 Apr 2022, 04:39Not only that´s illogical but it will be inconsistent too. Before, people that were quickest on qualifying but did not start the GP on pole, were not given the "pole statistic"(for instance, Schumacher on 2012 or Leclerc last year, at Monaco), but now they willerudite450 wrote: ↑17 Apr 2022, 15:16How does that work exactly? "Well done. You are credited with pole but you won't start on pole."
I still can not understand why they are not simply running a Q for the Sprint on Friday and a Q for the race on Sunday. If you just look at the timetable of this weekend it is ridiculous. Some action in the morning with much too much stretch between and then for a normal spectator nearly 2 hours noting until the pit lane opens....erudite450 wrote: ↑19 Apr 2022, 08:57I couldn't agree more!Artur Craft wrote: ↑19 Apr 2022, 04:39Not only that´s illogical but it will be inconsistent too. Before, people that were quickest on qualifying but did not start the GP on pole, were not given the "pole statistic"(for instance, Schumacher on 2012 or Leclerc last year, at Monaco), but now they willerudite450 wrote: ↑17 Apr 2022, 15:16
Most wheater sites say the same.erudite450 wrote: ↑19 Apr 2022, 09:01Saturday seems a nailed on wet day with a 100% chance of rain at the moment on Google. The rest of the weekend might be dry or changeable. Good decision by most teams not to take updates to Imola. It might be a wild weekend.
