McLaren MCL36
Re: McLaren MCL36
How bout here, that winglet's traling edge going towards or away from the upright?
See, you can argue with me, fine, but you can't argue with physical evidence.
Re: McLaren MCL36
godlameroso wrote:
21 Apr 2022, 19:40
So that flow vis in the Ferrari diffuser, it's not going outwards? It looks like it's outwashing, especially at the top of the diffuser. Are my eyes deceiving me and is that actually inwash?
Of course you could conclude that. However, what you also notice is that there is a whole part that isn't covered.
What you might also notice is flow that is nearly flowing back to itself, as well as the vast majority of the flow painting the sidewall.
You are drawing your conclusion on the small top edge of the diffuser
Re: McLaren MCL36
godlameroso wrote:
21 Apr 2022, 19:40
wesley123 wrote:
21 Apr 2022, 18:51
godlameroso wrote:
13 Apr 2022, 01:59
https://pbs.twimg.com/media/FMSIv6yXoAg ... ame=medium
Don't believe your lying eyes :lol: 3 cars 3 different attempts to create outwash with the diffuser within the regulations with flowvis to boot, but yeah. Fake internet points = correct around here I guess.
There's no real outwash going on. The diffuser walls are straight, and actually tuck inwards at the base.
Diffuser designed for outwash looks like this:
That sort of curvature of the walls is no longer allowed.
Look how wide the diffuser is relative to the brake ducts.
_cerber1
258
Re: McLaren MCL36
charliesmithhd
67
Re: McLaren MCL36
_cerber1
258
Re: McLaren MCL36
SmallSoldier
SmallSoldier
479
Re: McLaren MCL36
Detail on the MCL36 Beam Wing:
Vía: AMUS
MrGapes
33
Re: McLaren MCL36
The team has been using the same high df rear wing for every track now right?
SmallSoldier
SmallSoldier
479
Re: McLaren MCL36
Very nice picture of the MCL36 rear brake ducts… Notice the exit of the hot air coming from the ducts and the intended direction of the hot air.
Also the winglets on the assembly
Vía: @SalaStampa
Re: McLaren MCL36
MrGapes wrote:
24 Apr 2022, 03:50
Not sure what you were expecting, Imola isn't a low DF track. When the DRS is enabled that Flap does open you know. The lower part of the Rear wing, the leading edge is raise a bit in comparison to the middle and that cuts the amout of air it will scoop. I'm sure they can change the angle ever so slightly and change the amount of DF/drag it will create.
vorticism
323
Re: McLaren MCL36
SmallSoldier wrote:
26 Apr 2022, 16:06
https://i.imgur.com/HQhq3X0.jpg
Vía: @SalaStampa
Return of the monkey seat
𓄀
_cerber1
258
Re: McLaren MCL36
Favorite chassis part =P~
Marc.W
26
Re: McLaren MCL36
_cerber1 wrote:
26 Apr 2022, 19:30
https://ibb.co/vdSj51L
So that's where the upturn in performance came from :lol:
MrGapes
33
Re: McLaren MCL36
diffuser wrote:
26 Apr 2022, 17:58
MrGapes wrote:
24 Apr 2022, 03:50
I never questioned their choice of rear wing, I was just asking if they have used the same rear wing for the last four races….
Re: McLaren MCL36
MrGapes wrote:
27 Apr 2022, 02:16
diffuser wrote:
26 Apr 2022, 17:58
MrGapes wrote:
24 Apr 2022, 03:50
Ok, sorry misunderstood.
