lh13 wrote: ↑25 Apr 2022, 21:07
dialtone wrote:lh13 wrote: ↑25 Apr 2022, 09:25
Failing to overtake someone is your definition of 'foot wrong'? Laughable if that's the case.
well, it is. If 3 times you get baited to give up DRS in the second straight, yeah that's a foot wrong. is it only when Charles does it?
Well here's a bit of explanation for you, and I'm sure it is not going to change your mind.
The reason Max was getting overtaken before turn 4 was because he was taking a compromised line through 1-2. If he stayed behind Charles, then Charles takes perfect line through 1-2, and carries more speed on the straight. That straight is not long enough to overtake for cars with similar pace, even with DRS, especially once defender takes inside line. 2 times out of 3, Charles 'barely' overtook Max who was running a compromised line, so it is safe to assume there was no way Max was going to overtake Charles there unless Charles compromised his exit out of 2, which he wasn't going to do as he was not defending at all into 1.
And you should have known, Charles was carrying 10-15 kph less into turn 1, due to different deployment settings?!. Max would have had to go even slower to keep himself behind Charles, which isn't an easy thing to do/judge when you're driving flat out, and can disturb the rhythm of the driver behind the wheel. He took his chances when he could, its simple as that.
Oh boy, where do I even begin... During the passing Charles wasn't carrying 10-15kph less but 30+ kph less, Charles was skimming speed to below 285kph, while Max was well over 310kph using DRS. It's widely known, even by Driver61, that Leclerc was in fact braking to have DRS before T1 and into the second straight, like he did in Jeddah the following race (where it also worked the first time he did it there). I even showed the telemetry for this in the race thread after the race.
The DRS detection game was a matter of few meters, Max just needed to brake a bit more instead of lounging like he did every single time until he locked his wheels, but he wasn't expecting Leclerc to play like that, he didn't even expect Leclerc to play that way in Jeddah the first time Charles did it, although there he sure learned it for the following 2 times though, even closing his DRS before the detection to avoid passing Charles and giving him DRS back.
Max's point wasn't not to pass in T1, he should have passed in T1 but he absolutely needed to avoid Charles getting DRS for the 2nd straight. I also like how that straight is not long enough to overtake, even with DRS but Charles did it 2 times haha
and "barely" you say, both times clearly ahead before the corner.
Deployment settings haha
. It's called racecraft and Max didn't have a good showing in Bahrain, but he's not going to make those mistakes again because he's strong.
