Williams FW44
Mr Brooksy
Re: Williams FW44
cplchanb wrote:
19 May 2022, 18:04
so have they completely abandoned the hole behind the sidepod inlet concept?
It hasnt seen a single race after pre season testing.
It looks like it doesn't it. I wonder if there was a query to the FIA and because it wasn't primarily designed for cooling (that was the reason for bringing the louvers back correct?) they outlawed it?
WilliamsF1 fan since 1989
AeroDynamic
349
Re: Williams FW44
jagunx51
185
Re: Williams FW44
GrizzleBoy
GrizzleBoy
33
Re: Williams FW44
Bodywork around the stay looks a little rough too doesn't it?
Moctecus
150
Re: Williams FW44
Big Tea
Re: Williams FW44
McMika98 wrote:
20 May 2022, 18:22
How is Albon dragging this piece of garbage truck to 2 point scoring race is unfathomable. About a second away from the back of midfield. Race pace equally as bad. They need to take Aston Martin route 😤.
They been working on it for months :evil:
Mr Brooksy
Re: Williams FW44
Moctecus wrote:
20 May 2022, 19:27
https://i.imgur.com/w41gyuL.jpg
The slot gaps in the new rear wing seem strange, why would the radial edge gaps not be consistent with the flat gap?
jagunx51
185
Re: Williams FW44
cplchanb
cplchanb
Re: Williams FW44
Any keen eyed folks can tell anything from the red flow vis??? Is there any problem with the rear wing or diffuser aero?
McMika98
McMika98
-24
Re: Williams FW44
Now that the Merc seem to work, maybe Williams should also try the zero sidepod concept and have the side impact structure outside the sidepod. The 2 Haas with zero upgrade in Q3 shows how lacking this car is. Zero downforce.
Re: Williams FW44
McMika98 wrote:
21 May 2022, 18:07
This car would need monocoque changes to copy the Mercedes.
A lion must kill its prey.
Moctecus
150
Re: Williams FW44
The FW44 sporting some flow-vis again on Friday.
Not what you want to see 7 races into the season without any major upgrades and with no new parts brought to this track. Hopefully not a sign of them still being at a loss with understanding their car.
tomazy
tomazy
208
Re: Williams FW44
They did bring some new parts for Spain, diffirent rear brake duck winglets I think, and they are probably just monitoring how those parts interect with the lower DF rear wing.
Re: Williams FW44
I'm surprised they haven't flat out copied the RedBull concept at this point. It's not like they have anything to lose.
Francesc
Francesc
49
Re: Williams FW44
It will be interesting to see with what they come up at Silverstone. With the amount of time they've had to develop the upgrade I hope they don't dissapoint us. [-o<
In Baku the FW44 was one of the cars that had the least porpoising. I don't know if it was because they were running it quite high or what.
