I watched the live stream. He was hooked up to the fuel line.PlatinumZealot wrote: ↑10 Jun 2022, 17:39Could that he did not refuel while in the pits or something. I don't really pay attention to predictions based on practice times though.
yeah, it's possible of course, or he also could have done gone for tyre saving as there were only a couple of minutes left anyway - I was just wondering how anyone could say with certainty. Normal procedure would be a normal "full" tank run, I think.Juzh wrote: ↑10 Jun 2022, 17:38Assumption is Perez was doing a race start sim with full fuel on mediums and verstappen was simulating a stint much later on in the race with maybe half a tank of fuel.
It is of course possible they were both doing race start sim, just on different tyres. In this case verstappen on soft is looking much better than perez on medium.
Alonso didn't use drs at any point. Tsunoda was at this distance for 3-4 laps and couldn't do anything. Alpine is just very low on downforce.
Yeah, Verstappen on lower fuel certainly makes sense. RB kinda do it most of the time. On friday in Bahrain everyone was talking about their low 37 run and then they started the race in the mid 38s.dialtone wrote: ↑10 Jun 2022, 18:06https://i.imgur.com/t0mZFX8.jpeg
* Starting speed for Ferrari is slower than speed at finish line, this suggests a bit of margin there, according to delta_time that's about 0.05s
* Similarly in the straight to T3 there's some slower speed compared to RedBull which isn't there in the final straight acceleration and again it's a loss of about 0.05s.
* The loss of RPM at the end of the straights from Ferrari suggests either clipping or a low enough mode, however the loss of RPM doesn't happen in the straight to T15 (3000m distance in the lap).
* On the other hand, RedBull can probably upshift faster than they are doing in this lap, so there's some margin in both cars.
* RedBull is very good in the first 2 corners in S1.
* Other than those points, S1 is basically dead even timing wise.
* In S2 Ferrari manages to build a good lead thanks in large part to better traction out of twisty parts of S2 before again RBR catches up in speed at the end of the straight into T15. Ferrari somehow manages to be both later at braking and earlier on the accelerator.
* Top speed difference at finish line is 332kph for PER and 327 for LEC. Hard to know what causes this, could the engine mode of course, but I think it's more about porpoising and Ferrari might not be able to bridge this top speed gap at the end of the main straight.
Overall I think on the single lap Ferrari may have slightly bigger edge, but it will certainly be very close.
https://i.imgur.com/YzRlpeT.png
Race sim is a lot closer. According to Sky Italy VER ran with less fuel on board, they had a person in front of the RBR box to check this stuff. The race pace here anyway is very very close between the cars, so it will be a very close race.
https://i.imgur.com/Cz67Dsf.png
Rest of the grid is nowhere... Merc seems good 3rd followed by Aston Martin and Alpine. I think this is the biggest gap in race sim so far, probably due to longer lap anyway.
It's a compromise. If they want to avoid bouncing, they have to run stiff and/or increase the ride height which would lead to reduced performance through other sectors while giving stability on straight. It may also affect the tyre life. It's not like they are a bunch of fools that come to the track with the set up compromise they are running. Who knows, if they try to stop bouncing, it might make the overall performances worse than it is now.PlatinumZealot wrote: ↑10 Jun 2022, 18:37Mercedes should gain at least 0.5 seconds if they can tone down the bouncing. They will be 0.8s a lap slower at best basically.
Stiffer? You mean softer I think? Stiffer suspension only would make the porpoising worse...silver wrote: ↑10 Jun 2022, 19:11It's a compromise. If they want to avoid bouncing, they have to run stiff and/or increase the ride height which would lead to reduced performance through other sectors while giving stability on straight. It may also affect the tyre life. It's not like they are a bunch of fools that come to the track with the set up compromise they are running. Who knows, if they try to stop bouncing, it might make the overall performances worse than it is now.PlatinumZealot wrote: ↑10 Jun 2022, 18:37Mercedes should gain at least 0.5 seconds if they can tone down the bouncing. They will be 0.8s a lap slower at best basically.
No it wouldn't because it would require more force to lower the car to the point when the floor is stalling lifting the minimum speed where porpoising presents itself.Gillian wrote: ↑10 Jun 2022, 19:17Stiffer? You mean softer I think? Stiffer suspension only would make the porpoising worse...silver wrote: ↑10 Jun 2022, 19:11It's a compromise. If they want to avoid bouncing, they have to run stiff and/or increase the ride height which would lead to reduced performance through other sectors while giving stability on straight. It may also affect the tyre life. It's not like they are a bunch of fools that come to the track with the set up compromise they are running. Who knows, if they try to stop bouncing, it might make the overall performances worse than it is now.PlatinumZealot wrote: ↑10 Jun 2022, 18:37Mercedes should gain at least 0.5 seconds if they can tone down the bouncing. They will be 0.8s a lap slower at best basically.
I thought stiffer suspension means the porpoising happens from a higher speed (more tolerance) but increases the intensity. If I'm wrong, could you point me to where I can learn some more?dialtone wrote: ↑10 Jun 2022, 19:18No it wouldn't because it would require more force to lower the car to the point when the floor is stalling lifting the minimum speed where porpoising presents itself.Gillian wrote: ↑10 Jun 2022, 19:17Stiffer? You mean softer I think? Stiffer suspension only would make the porpoising worse...silver wrote: ↑10 Jun 2022, 19:11It's a compromise. If they want to avoid bouncing, they have to run stiff and/or increase the ride height which would lead to reduced performance through other sectors while giving stability on straight. It may also affect the tyre life. It's not like they are a bunch of fools that come to the track with the set up compromise they are running. Who knows, if they try to stop bouncing, it might make the overall performances worse than it is now.
