etusch wrote: ↑09 Jun 2022, 22:13
PlatinumZealot wrote: ↑09 Jun 2022, 21:56
etusch wrote: ↑09 Jun 2022, 21:03
Where do you know that it is for air? or what makes you think it is for air?
Even so why do you know it is not through throttle body?
I never claimed it was air, but if it were, and depending on the answer: through throttle to engine, or bypass throttle to exhaust; we can identify some tricks that Honda could do.
I interested with engine and gearbox more then aero. I also want to find out what it is. But we should find out what it is first and then you can question if it is leagal or not.
So as forum we have more pride in figuring out things first before Scarbs and the others? For shame!
You can see there is what looks like a return header at the base of it.
It could also be water cooling.
I had an idea of the prechamber having it's own air intake valve built into the injectors.. Sort of a loophole.
The other idea is that if it is air in the pipes it just simple cooling.
Edit..
I wonder if it is a cable too... Anyway.. Worth the guesses!
