2022 Mercedes-AMG | Petronas F1 Team
Zynerji
111
Re: 2022 Mercedes-AMG | Petronas F1 Team
25 Jun 2022, 16:57
Russell's higher DF rear wing was good in the wet, but I doubt that he could have held back Lewis (aka the guinea pig) who was nearly half a second a lap faster in the dry.
They are ALL guinea pigs. It's a prototype series.
Some just perform under pressure better than others.
Zynerji wrote:
25 Jun 2022, 20:19
25 Jun 2022, 16:57
Guinea pig means someone who is experimented on.
Lewis has been trying experimental (unproven, unorthodox) setups up until now and he doesn't want to do that anymore.
Zynerji
111
25 Jun 2022, 22:04
Zynerji wrote:
25 Jun 2022, 20:19
25 Jun 2022, 16:57
Unorthodox for whom?
Stu
Zynerji wrote:
25 Jun 2022, 22:15
25 Jun 2022, 22:04
Zynerji wrote:
25 Jun 2022, 20:19
And in what manner?
They ran with different rear wings in Montreal, but I didn’t see any images of each from the rear, so there could have been different beam wing set-ups as well.
The ‘apparently’ very limited suspension movement/adjustment of the W13 is a worry (it really constrains the mechanical solutions to both porpoising and bouncing - if the two are unlinked); it is almost as though there is an over-reliance on design tools (that are themselves reliant on accurate coding and input data).
I have my doubts over the ‘stub’ winglets covering the upper SIS; they are required to have an open section (meaning that they are not a pure aerofoil) which is intrinsically draggy, I could see some sense in it IF it was utilised as a part of the cooling extraction (it would/could be used to create an air curtain to control front tyre wake - think Dyson air blade). However the surfaces/sections rules mean that this is not possible without having the ducting required built int the chassis structure.
What is worth bearing in mind is that for all of the talk of ‘huge’ gaps to the front of the grid, the percentage difference between a 90 second lap-time & a 90.7 second lap-time is tiny (0.7777777778%), so the car is far from being fundamentally poor; it is just a slightly less good interpretation of the rules.
pursue_one's
97
Stu wrote:
26 Jun 2022, 09:13
Zynerji wrote:
25 Jun 2022, 22:15
25 Jun 2022, 22:04
And in what manner?
Rear wing comparison
chrisc90
Aside from the rear wing, the upper beam wing has a much higher angle on George's car than lewis.
chrisc90 wrote:
26 Jun 2022, 12:54
Different top corner shape on the rear wing flap too.
I'm sort of expecting a different side pod concept for Silverstone. I imagine it will still be zero pods but it will be low and horizonal with a ramp like the cars from the eighties.
adrianjordan
Have they confirmed a significant update?
Favourite team: McLaren
De Jokke
Not that I know of, only that they will bring 'bits' to Silverstone, so quite pessimistic :cry:
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
SuperCNJ
SuperCNJ
f
26 Jun 2022, 14:38
Changing concept mid-season is a big deal and not something that can be done quickly. It doesn't seem that long ago when Merc were saying they didn't fully know the causes of the porpoising so its difficult to believe they can switch concepts, integrate, build and test the new concept in such a short space of time whilst keeping to budget. Great if they manage to pull it off, would love to see them in the mix up front but I remain a bit skeptical about a change of concept.
SuperCNJ wrote:
27 Jun 2022, 15:45
f
26 Jun 2022, 14:38
Agreed but maybe I did not give a detailed enough description. I believe this will still be the zero pod concept, but with a longer ramp to the rear thereby stiffening the floor, and a shape that widens in plan-view to create more out-wash.
des_1986
des_1986
Interview with Andrew Shovlin which includes some small detail about upgrades for Silverstone
https://www.formula1.com/en/latest/arti ... r4TQl.html
"Not quite [sidepods] but we're looking at different front wings, rear wings, there'll be some changes on the floor, so a few other bits and bobs. But a lot of development this year is going on under the cars where people don't see it, but this will be a bit more obvious to those looking."
mstar
mstar
It be a new floor. And the edges of the floor and new front and rear wing it looks like. I wonder if suspension? as lewis ran experimental rear suspension in Baku but it was a disaster
Spoutnik
Spoutnik
