The optimum CoP is ~1.92m or 46.6% front balance, yes.
Three or more...
Submitted a ticket on the support websiteLVDH wrote: ↑06 Jul 2022, 17:55Three or more...
I have fixed the issue on the support forum. Somehow I cannot find out how to make sure you have to tell my which exact OS you are using, so please make sure to tell in your messages. But support forum working or not, I am trying to replicate issues on Windows. In any case, Windows seems to be able to run Linux quite well now. Maybe someone knows if it makes sense to jam MantiumFlow into a OF Docker Image. This would allow us to use much more recent versions of OF!
I can have a look at this.
I think it is needed as it helps keeping some other rules simpler.
I agree on this. Matteo was nice enough to create these parts. However his parts always translate into huge stl files. I am not sure why that is. My plan is to recreate these parts in FreeCAD. This will have to wait until Monday though. My plan is to replicate his geometry as closely as possible. The wheels will stay as they are, so they will remain to be a bit large in file size.
I can have a look at this, but you should not get your hopes up. One reason being is that we have to settle at some kind of geometry at this point. We are getting close to our first race.
You have to elaborate on this.
Yes and no, this is way down on my list.
Thanks, it seems there is even more broken with the support sites. I am one it and will try to answer as soon as I have a better one than I do right now.yinlad wrote: ↑06 Jul 2022, 23:24Submitted a ticket on the support websiteLVDH wrote: ↑06 Jul 2022, 17:55Three or more...
What do you guys think about allowing the suspension to be rotated some amount (maybe +/- 10 degrees?) around the respective wheel center? And then we could just include the rotated parts with our submissions.
I think this is a very very good idea (provided we define a single front wheel axis: the wheels have camber so we have two, so each suspension would rotate around its own wheel). Maybe 10° is too much (considering the rod attachments), but 5° would be OK.spacehead3 wrote: ↑08 Jul 2022, 03:16What do you guys think about allowing the suspension to be rotated some amount (maybe +/- 10 degrees?) around the respective wheel center? And then we could just include the rotated parts with our submissions.
I meant this:
Yeah, sound good.spacehead3 wrote: ↑08 Jul 2022, 03:16What do you guys think about allowing the suspension to be rotated some amount (maybe +/- 10 degrees?) around the respective wheel center? And then we could just include the rotated parts with our submissions.
The guys checking the rules would go nuts as well.variante wrote: ↑08 Jul 2022, 12:11Yeah, sound good.spacehead3 wrote: ↑08 Jul 2022, 03:16What do you guys think about allowing the suspension to be rotated some amount (maybe +/- 10 degrees?) around the respective wheel center? And then we could just include the rotated parts with our submissions.
Suspension guys would go nuts about that, but who cares
I think a better idea would be to rotate the sections individually. This is pretty easy to do with the builtin tools in OF if the upright and wishbones are in seperate stls:LVDH wrote: ↑08 Jul 2022, 14:57The guys checking the rules would go nuts as well.variante wrote: ↑08 Jul 2022, 12:11Yeah, sound good.spacehead3 wrote: ↑08 Jul 2022, 03:16
Anyway, maybe I am missing something here and it is indeed a good idea. Please keep it as a suggestion for next season as I see no way of having enough time to implement this aspect.
Yes, although slightly more complicated, this would be closer to ideal.
