One thing is sure nugnes can be sometimes unreliableFDD wrote: ↑14 Jul 2022, 15:46If this info is true then that is a positive one
https://it.motorsport.com/f1/news/f1-re ... /10337581/
Isn't there a rule against slapping in links in a different language, without further info?FDD wrote: ↑14 Jul 2022, 15:46If this info is true then that is a positive one
Use a translator like the rest of us.mzso wrote: ↑14 Jul 2022, 17:15Isn't there a rule against slapping in links in a different language, without further info?FDD wrote: ↑14 Jul 2022, 15:46If this info is true then that is a positive one
There should be.
I'd not be surprised given the PU issues Ferrari have had this season, if they've elected to test the new ERS system in the Haas, to gather real world data before they deploy the ERS in it's own cars.
That in itself isn't surprising, but it's obviously false as it would require homologation, the only one available for ERS, which would be reported by all of the more authoritative journalists like Duchessa or Fabrega.
It's somewhat of an impossibility. The new spec would have to be declared as teams are only permitted the one spec update per season. From then onwards, it's very restrictive what changes can be made. Ferrari wouldn't want to be handicapped in their development due to having the new homologated spec already declared in the Haas and then being heavily restricted in what can be changed afterwards.
The Homologation deadline for the ERS is in September. I would expect by this point the ERS will be nearing completion or be ready to use. If there is anything experimental being used in the Haas then it will have been cleared by the FIA. Could be a tweak to how the ERS is installed or software tweaks.AR3-GP wrote: ↑15 Jul 2022, 21:26It's somewhat of an impossibility. The new spec would have to be declared as teams are only permitted the one spec update per season. From then onwards, it's very restrictive what changes can be made. Ferrari wouldn't want to be handicapped in their development due to having the new homologated spec already declared in the Haas and then being heavily restricted in what can be changed afterwards.
Do you think Merc/Honda/Renault would let Ferrari use Haas as an "experiment"? I don't think sotaperoo2k wrote: ↑18 Jul 2022, 22:42The Homologation deadline for the ERS is in September. I would expect by this point the ERS will be nearing completion or be ready to use. If there is anything experimental being used in the Haas then it will have been cleared by the FIA. Could be a tweak to how the ERS is installed or software tweaks.AR3-GP wrote: ↑15 Jul 2022, 21:26It's somewhat of an impossibility. The new spec would have to be declared as teams are only permitted the one spec update per season. From then onwards, it's very restrictive what changes can be made. Ferrari wouldn't want to be handicapped in their development due to having the new homologated spec already declared in the Haas and then being heavily restricted in what can be changed afterwards.
At some point you have to stop development and commit to what you've got.
The problem for Ferrari is likely the PU reliability taking attention away from the deployment of the new ERS.
Valtteri Bottas has summarised the problem as “oscillation that comes from the clutch itself and then the way the torque goes to the rear wheels is not consistent”.
“We tend to lose positions on average at the start and that’s not great because the midfield is so tight that once you drop behind somebody, then you’re stuck for like 20 laps and it doesn’t make your life any easier.
“Hopefully now it’s OK.”
Ferrari driver Carlos Sainz couldn’t be drawn on whether Ferrari was running the new clutch but did acknowledge the problem.
“Yeah, we’ve identified an issue on our car this year that is not allowing us to perform the starts that we were doing last year,” Sainz said.
“Probably it’s affecting our fellow engine team-mates. But we know where the problem lies in.
“We’re keeping it very private. We don’t speak a lot about it because it’s not like in every start, we are falling back or anything. But it’s probably not the best start that we can get with this car. And hopefully, we will keep improving it through the year and into next year.”
I think it is the other way around. The PU has to be cranked up or set up for lean mixture to save fuel during the race. It looks like their ERS is less efficient than Honda, so Ferrari tries to compensate it with the ICE mapping.
"We had problems and we're never safe. However I think we understood the problem, even if we've not solved it completely. We're managing it, which means we can enter a race with the confidence and peace of mind that we'll finish it without problems"“I problemi ci son stati e non si è mai al riparo. Penso che abbiamo capito il problema, seppur non sia ancora stato risolto definitivamente. Lo stiamo gestendo, che significa poter affrontare la gara con la consapevolezza e la tranquillità di finirla senza problemi”.
I didn't think that was the PU. I thought it was the diffuser rubbing on the curbs.ispano6 wrote: ↑26 Jul 2022, 04:11The Ferrari PU seems to burn oil or release a plume of smoke when it goes off throttle. It happens when Sainz almost overtakes Perez at the end of the straight on lap 41. Could it be something to do with the ERS via the MGU-H, spike the temps to charge the battery?
