2008 vs 2009 Front Wing
a6zz
a6zz
I have modelled both the 2008 and 2009 front wing on CFD, following quite close to the regulations...the results i had achieved for Drag and Lift were almost the same. Even tho they were different geometries (they looked quite similar to the Mclaren 2008 and 2009 front wings) Anyone know why they had the same results?
Callum
Re: 2008 vs 2009 Front Wing
Can you show us any graphs or figures?
The first thing that i thought of was that the wings are longer but do they have a larger surface area? I also know that a longer wing is more efficient which may explain why lift/drag ratios are similar.
ESPImperium
ESPImperium
64
Care to show your designs, and end data???
I feel that the OWG should have kept the front end regs more or less the same, maybes lowering the wing a little more and banning spoon wings, but keeping the 2008 width and little add ons like the full bridge wing.
I can see the regs dictationg the front wings to go back to the 2008 width if speeds are getting high, as well as a little higher as well. But to counteract that they will allow infinite changes in wing angle each lap within a +/- 9 degree sweep.
However that will be changed with the front wheel width as well to try and reduce front end grip when the current regs get to the stage that the cars are too fast.
jayjay
jayjay
yes please could you show us plots, maybe graphs of differences
you know 2009 rules were more complex..
Scotracer
Scotracer
That's what I was expecting.
Powertrain Cooling Engineer
a6zz
a6zz
Sorry people,
Just been extremely busy and my computer had crashed so I lost most of my work,
anyways i am running the front wings of different speeds on the HPC, and I will post the results as soon as i get them
