etusch
131
What Verstappen's sping remembered me =D> =D>
mendis wrote:
01 Aug 2022, 04:58
Red Bull have now landed in a position where they can start doing track work of the parts for the next year's car. One car can focus on quali/race work, which would be Max and Perez can be used on Fridays for next year's development work.
They will need it because they now have the least windtunnel time.
A lion must kill its prey.
chrisc90
01 Aug 2022, 17:46
mendis wrote:
01 Aug 2022, 04:58
Can they use next years budget to make parts already and test them on the '22 car?
chrisc90 wrote:
01 Aug 2022, 19:21
01 Aug 2022, 17:46
mendis wrote:
01 Aug 2022, 04:58
The budget cap is an annual cap which can be spent however they see fit towards this year's car or next year's car. So no they cannot "use next year's budget" in the literal sense of spending money from 2023's cap.
chrisc90
01 Aug 2022, 21:55
chrisc90 wrote:
01 Aug 2022, 19:21
01 Aug 2022, 17:46
That rules that out then. I reckon RB would be on the limits of the budget cap this year, unless they allocate some budget towards next seasons project in terms of parts that can be made relatively cheap and easy to implement.
Speaking of which, if costs are managed on an annual basis, be interesting to know how they balanced budget with the 2021 season and working on the 2022 car with a whole new set of regulations. I know it'll have been over 2-3 years of development, but I still imagine there would be significant cost involved.
chrisc90
Again - apologies for those not on Facebook or Geo-blocked from watching it.
Lovely little piece from Hannah Schmitz about the RB strategy for the weekend.
Re: Red Bull RB18
henry wrote:
20 Jun 2022, 15:03
Meanwhile…
Toto Wolff mentioned that the RB18 runs more rake than most. Obviously not the tail high levels of yesteryear but even a small rake could, I think, have some benefits. It would, for instance, lead to the front of the floor striking the ground instead of the whole floor, this will bring into play the front floor suspension mechanism which will reduce the contact force and hence drag. This would definitely reduce peak Gs compared with a full floor slam.
It will also allow lower spring rates at the rear which will lower the natural frequency of any oscillations giving the undercar airflow more time to reattach if it were to become disturbed.
The RB18 also has a good deal of anti-dive in the front suspension kinematics, this will reduce the load on the front floor during high speed braking manoeuvres. I made an earlier suggestion that hysteresis in the front floor suspension could be beneficial, maybe the anti-dive points at it being less useful than I suggested.
Whenever these new cars get anywhere close to 150KPH, they appear to be leaning backwards. The front floor has slot opening and the rear appears to be scraping the track . Think that rake is more about getting the car to rotate easier at slow speeds. The @as comes up and induces oversteer.
mendis
mendis
19
chrisc90 wrote:
01 Aug 2022, 22:30
01 Aug 2022, 21:55
chrisc90 wrote:
01 Aug 2022, 19:21
The way teams really operate is, by around July/August time frame, the current car's work is almost stopped and the next year's car takes precedence and majority of resources would be moved to it. So, in that sense, the work for next year's car would be carried out by 2022 spend. Budget cap, like AR-3GP said, is annual budget cap. It does not dictate which car's work you can do with 2022 budget or in other words, it does not stop using 2022 spend for creating 2023 car parts. Even the wind tunnel time they have now, can be used for 2023 if their new wind tunnel model is ready, which forces this year's model to be out of wind tunnel.
In short, Wind tunnel and CFD times and budgets are static, but you can use it to build either 2022 or 2023 cars.
mendis
mendis
19
Re: Red Bull RB18
henry wrote:
20 Jun 2022, 15:03
Meanwhile…
I remember at the beginning of the season at testing, Scarbs saying the new front suspension layout of RB18 was pro dive and not anti-dive like you are saying. His reasoning back then was that, with front wings now situated higher than previous generation cars and the rear is set to run lower without loads of rake of the past, they need front of the car to now go down in cornering to get better aero platform. I am surprised you say, it's anti-dive setup.
gandharva
252
chrisc90 wrote:
01 Aug 2022, 22:49
h++ps://fb.watch/eDZrfwwUc3/
I even block this Facebook --- on purpose. ;)
https://honda.racing/rbr-sat/post/honda ... wer-trains
Excellent news
Honda extend their technical support of the power unit to 2025
https://www.redbullpowertrains.com/int- ... nt=Article
Pat Pending
Pat Pending
02 Aug 2022, 13:10
Excellent news
Wouldn't surprise me if this is an indication that RB have already decided that the Audi collaboration from 2026 onwards makes RB Powertrains superfluous to requirements.
Sieper
73
Not superfluous, they just poached another engine department employee from Mercedes, AMG. I think there they will work on the new PU.
Honda, are the rumors, would like to return but have been offered Alpha Tauri and they want the A team to cooperate with.
02 Aug 2022, 13:10
Excellent news
I thought this was confirmed a long time ago?
02 Aug 2022, 15:13
02 Aug 2022, 13:10
Excellent news
Only delivery of the PUs until 2026 was confirmed. Not providing the technical guidance.
