I would think a flat 4 at 20k RPM would be worth hearing
This may interest some https://www.youtube.com/watch?v=WIA7vBx_dvM
Skip to 1.15 if you like
That's awesomeBig Tea wrote: ↑11 Aug 2022, 15:12I would think a flat 4 at 20k RPM would be worth hearing
I don't follow what the cost cap has to do with it. Under naturally aspirated piston engine regulations there will be a cylinder count which is best. The actual extra cost of producing an engine with more cylinders is likely negligible, we are talking racing engines built with near unlimited budgets, not Dacia Sandero mass production.
Sure, why not. But given three or four cylinders were not optimal for 3000cc in 1995, they are unlikely to be optimal for 3000cc in 2026.If someone wants a flat 4 or inline 3 why force them to go the V10 route?
The cost cap would mean there is no scope for some to spend endless on 'niche' engines just to give one particular team an advantage. Any engine built will have to be useable, and preferably transferable.JordanMugen wrote: ↑11 Aug 2022, 21:03I don't follow what the cost cap has to do with it. Under naturally aspirated piston engine regulations there will be a cylinder count which is best. The actual extra cost of producing an engine with more cylinders is likely negligible, we are talking racing engines built with near unlimited budgets, not Dacia Sandero mass production.
For 1000cc in MotoGP the optimal cylinder count was probably five or six, probably a V6 being the best configuration for power, at the expense of size and weight compared to the V4. But FIM initially set the maximum cylinder at five, so Honda tried the compromise V5 engine instead which was very successful, before FIM reduced the maximum cylinder count to four (temporarily reducing the swept capacity to 800cc in the process).
For Grand Prix cars, under 3500cc regulations ten cylinders proved most promising, while twelve and eight also had merits. Eventually engine makers converged on ten cylinders being best for the capacity which was later reduced to
3000cc. If the swept capacity had been 4000cc however, then twelve cylinders would possibly be best.
Notably Toyota were keen to try again with 3000cc and twelve cylinders for the year 2000, as Ferrari had done in 1995, but the FIA prohibited this before Toyota raced it.
But you are quite correct that the engine with 1000cc per cylinder should have less friction. Even in road car (as opposed to truck) engines though, 1000cc per cylinder is very unusual so I'd be surprised if it proves to be the optimal configuration in a petrol racing engine.
Outside of comments from Andy Cowell which counter your beleifs.. Simple comparisons can be done to shoe that the combustion/heat managment is THE big differntiator...Just_a_fan wrote: ↑11 Aug 2022, 14:38The PUs are 50% efficient overall. The ICE part alone isn't. Strip off the energy recover systems and you'd lose a huge chunk of that headline efficiency straight away.PlatinumZealot wrote: ↑11 Aug 2022, 13:40What?!!Just_a_fan wrote: ↑11 Aug 2022, 10:07
But much of the efficiency gain is not in the combustion chamber, it's in recovering as much of the energy that comes out of the exhaust ports as possible. A V10 isn't going to be anywhere near the overall efficiency of a current, complicated, hybrid system.
+1.PlatinumZealot wrote: ↑12 Aug 2022, 03:16Outside of comments from Andy Cowell which counter your beleifs.. Simple comparisons can be done to shoe that the combustion/heat managment is THE big differntiator...Just_a_fan wrote: ↑11 Aug 2022, 14:38The PUs are 50% efficient overall. The ICE part alone isn't. Strip off the energy recover systems and you'd lose a huge chunk of that headline efficiency straight away.
The strongest F1 V6 Hybrid started life at 42.5% thermal efficiency... It was adverstized the the electrical machines were greater than 97% efficent. ICE horsepower was calculated at 760hp or so.
In the efficiency of the engines increased year on year... 45%... 47.5%... 50%.. And above. The elecrtical load has not changed.. The MGUK is limited in its output. The ICE Power is now around 850hp. Thats 90hp gained through combustion...
How much did they gain from. Their already 97% effecient electrical machine? Not much.
Ferrari had one of the strongest hybrid systems. They were proud of their strong traction. Then their combustion magic was taken away....
Remember advancing of the ERS is important. It does help "long haul" racing which is great! You save more on fuel over a number of laps and this important for running lighter in the race.
But you are mixing up fuel mileage and thermal efficiency. With fuel mileage the strategy of manging the engines and recovering energy come into play more than the peak efficiency.
no
"Otherwise impossible"Tommy Cookers wrote: ↑12 Aug 2022, 11:06no
what you are all talking about isn't combustion efficiency
CE is just what % of fuel eg 95% is burned in the combustion chamber - that hasn't really been changed
what systems like TJI enable is satisfactory combustion of leaner mixtures than would be possible otherwise
plus F1 architecture (presumably) can have some post-cylinder combustion upstream the turbine
Tommy Cookers wrote: ↑12 Aug 2022, 21:31in the insulated exhaust pipe hot unburnt fuel vapour is dwelling at pressure surrounded by hot gas that includes oxygen
won't it oxidise aka burn ?
johnny comelately wrote: ↑12 Aug 2022, 22:01Looking at the: efficiency, RPM vs EVO, BHP I dont think so.Tommy Cookers wrote: ↑12 Aug 2022, 21:31in the insulated exhaust pipe hot unburnt fuel vapour is dwelling at pressure surrounded by hot gas that includes oxygen
That use of a burn in the pipes was from earlier eras which was a consequence of overly rich mixtures (on turbos) to partially control knock. That was a bonus then to spin up the turbo, no need now with the E.
With higher coolant temps and precombustion pressures, partial HCCI (maybe) and TJI they have IMHO virtually got rid of boundary layer quench, the biggest contributor to the unburnt MF.
Almost completeTommy Cookers wrote: ↑12 Aug 2022, 22:33you seem to be saying that combustion is complete in-cylinder
but combustion is incomplete due to inconsistency - with lean mixtures
inconsistency of combustion is what sets the limit to leaning
