Aston Martin AMR22
Re: Aston Martin AMR22
15 Aug 2022, 19:58
Just_a_fan wrote:
15 Aug 2022, 16:48
15 Aug 2022, 16:36
Keep in mind that Mercedes consulted the FIA on DAS.
So long as AM carry on near the rear of the grid, no one is likely to spend too much time protesting, unlike with DAS. If the end plate had been brought to the grid by one of the team near the front, there would have been a lot more lobbying. Such is F1 politics.
It will be interesting to see if one of the top teams implement a similar design, even if just to get the FIA to step in.
Williams had their mirror removed in 2020.
Williams 2019 mirror issue was caused by other teams raising it as an issue following pre-season testing. The FIA didn't just say "no" out of the blue.
Just_a_fan wrote:
16 Aug 2022, 17:09
15 Aug 2022, 19:58
Just_a_fan wrote:
15 Aug 2022, 16:48
Your previous comment was that no one cares about legality of back marker cars. I pointed out the '19 Williams in response.
A lion must kill its prey.
aral
aral
26
what on earth has the williams car to do with a technical thread about the AMR22 ? some proper moderation please !
aral wrote:
16 Aug 2022, 21:52
"Just a fan" said that nobody cares out the legaility of backmarker team's cars, insinuating that the rear wing of AMR would be not be legal if it was a front running team. AC3 said that isn't tru, they cared about the mirrors of the 2019 williams.
RedNEO
30
15 Aug 2022, 16:36
RedNEO wrote:
15 Aug 2022, 14:17
aleks_ader wrote:
30 Jul 2022, 11:23
Or you go for more downforce and more effective L/D ratio. So win win. Still i somewhat cannot see that as effective use of resources. And FIA will not like that development because goes against up wash mantra they tried to setup in those rules. And they were clear that any development against spirit of rules will get forbidden in rules quite quickly. Quite a risky development.
Aston Martin is smart they consulted with the FIA throughout its development it’s unlikely to get banned next year.
However, Aston Martin performance director Tom McCullough has revealed that as well as the FIA being happy with the regulatory aspect of the design, it was also satisfied that the concept did not scupper the intent of the rules to help the racing.
https://www.motorsport.com/f1/news/asto ... /10351971/
I’m sure Aston Martin would be flattered to have there endplate compared to DAS
RedNEO
30
Some interesting tidbits about the cost cap dictating the wing usage for this year and 2023 developments..
While the mixed weather conditions over the Hungary weekend meant the team did not get as much of an understanding of its potential as it would have liked, Aston Martin is looking to roll out the wing solution at other races later in the campaign.
But although the design brings more downforce without compromising drag, Aston Martin is not sure it will be able to use it at all races.
That is because the team is having to carefully balance its spending this year as it nudges close to the cost cap – so it may not be able to revamp all the different wings it has for variations in downforce levels.
Aston Martin performance director Tom McCullough said: “The cost cap is the thing there.
“We have a whole suite of wings, which we've already made. A lot of them we've used already through all the different efficiencies of the circuit, so to then go and remake those, it's just a bang for buck question.”
McCullough was clear that the new rear wing concept was not just for high downforce tracks, as it would work elsewhere as there was no compromises in terms of it adding drag to the car.
“It is an efficiency gain,” he said. “It can be used to varying degrees on different wings, so it's just a cost cap thing for us.”
McCullough said his team was at a state now where good ideas in the windtunnel were now only likely to be introduced on the 2023 car, because it was too expensive to bring them to the current challenger.
“We are in to the development of the 2023 car now,” he said. “If you think of it as larger bits, take as an example a wing, whether it's a front wing, or a nose, you could do a crash test, you could do a different philosophy, but that's a lot of money to do. You might as well wait.
https://www.autosport.com/f1/news/aston ... /10354143/
vorticism
323
rare to see a perfect iso side view.
𓄀
RedNEO
30
vorticism wrote:
19 Aug 2022, 01:28
https://www.racefans.net/wp-content/upl ... _HiRes.jpg
It does look the part just need to get it up to speed
CaribouBread
CaribouBread
101
From skinny to anorexic :shock: :wtf:
vorticism
323
That is the most interesting looking wing so far this season.
𓄀
vorticism wrote:
25 Aug 2022, 19:07
Even more than the Hungary wing on this car? Yes maybe actually - it looks quite ridiculous
RedNEO
30
With the knowledge that they ideally wanted to change all there rear wings (budget cap allowing) to be variations of the Hungary wing for efficiency gains I still find that one more interesting.
I’d like to see what it would have done to the look of this Monza spec wing which looks like an extreme low drag solution but without the benefits of the Hungary wing. It must have been produced before it surely.
CaribouBread
CaribouBread
101
CaribouBread wrote:
25 Aug 2022, 19:04
https://pbs.twimg.com/media/FbBYXkwWAAA ... ame=medium
Update to the anorexic wing, they've slapped on a substantial gurney flap
Comparison Rwing
