I already hear the crying about how strange the cars sound with the engines always screaming at least on 350kW.Red Rock Mutley wrote: ↑25 Aug 2022, 17:55Stu mentioned the accelerator pedal and injector regs. I've looked, but I'm not seeing them as limiting the ICE to MGU interaction. Perhaps he can help point out the specifics?Tommy Cookers wrote: ↑25 Aug 2022, 16:16my (first 2) suggestions above - can someone explain what would stop them working ?
5.14 & 5.15 (2026) define the relationship between the pedal map and the +ve torque to the rear wheels. However, they are framed in terms of net PU output. So, for the accelerator pedal at 0%, it's possible to run the ICE at +350kW and the MGU at -350kW for a net zero PU output.
The benefit is as you say, the turbine is already producing boost when the driver goes on the throttle, so all that problem with lag goes away.... plus you're harvesting energy for the later acceleration phase. All, in all, it seems very attractive to aim for running the ICE at full power for 100% of the lap, and modulating PU output using the MGU (at least in qualifying).
Braking is a point of contention, and there's a design choice of when to bring the ICE "on power". It's perfectly possible to do it early in the braking phase when the revs have dropped sufficiently for the output from ICE to balance the harvest from the MGU.
I wonder if anyone could actually calculate how much power can be generated in total. Obviously only break and part-throttle phases are in play, which might count for very little in Monza or Spa and such. But I guess the extra 350kW would be always available in monaco/hungary, on tracks where you least need it. The battery would be completely full after every turn...
