I've recorded some more footage over the season so i think i'll add an update to that post with a few more cars and comparisons for those i have nose cam video from several races as it's interesting to see how things have changed.
The colours and methods used will differ as i did not necessarily make those for this post but had them done in the meantime.
Red Bull: As outlined
in this post in the RB18 thread the wing flex seems to have increased significantly (for all elements) from the Bahrain test to the Canadian GP.
Check out the post for more images and gifs as it shows how i make those images in the first place, here's just the comparison
There seems to be some movement on the nose tip
yet the camera mounts look quite sturdy
meaning it's unlikely to be movement of the camera pod.
Mercedes: Also Bahrain vs. Canada, the main element was hard to make out but the edge of the paint is good enough, the main element seems to have a bit less deflection, the other ones have ~50% to almost double. Interestingly there does not appear to be any difference on the inside bits of the uppermost elements right of the metal connector.
I believe one possible explanation for this change was the new endplate introduced in Miami which potentially might have freed up the two upper elements for more movement.
Ferrari: Only a small change from Bahrain to Melbourne:
Here is the Ferrari FW in France in a bit more detail, it might be a bit confusing as i marked the lower edges as well
Low speed:
High speed:
Extreme deflection (on bumps etc) exceeding the avg high speed flex
Bahrain vs France, very similar to Bahrain vs. Melbourne, no difference on the main element, 25-30% more on the other ones
Three more cars:
McLaren in Barcelona
The nose movement here is likely the camera slightly moving under aero load as i can't see any part of the nose that seems to be fully 'fixed' relative to the camera ... on the contrary (
1,
2,
3)
The camera pod sits on thinner mountings
Alpha Tauri in Baku
Moving nose tip
really thick camera mount = movement is rather the nose tip (panel?), unlikely to be the camera
Aston Martin in Canada
I will not try to make a quantitative comparison between the cars themselves as the differences in camera angles, distance, fov, etc wouldn't allow for anything substantial, even when taking the decals etc as orientation for scaling them.
Edit: added a few more images etc
