Red Bull RB18
ispano6
153
Re: Red Bull RB18
31 Aug 2022, 14:11
The indent in the floor above diffuser has been there since preseason testing. The new parts were suspension shroud & sidepod reshaping at Spa. Floor hasn't been updated since France
Good stuff, mirror surround and engine cover too. It's been stated that Max felt the upgraded floor didn't help so he's opted to go with the floor without the cut-out, and clearly that is working for him. Whether the floor was the only spec difference between the two cars remains to be seen but clearly the RB18 in Max's hands was in dominant form for SPA.
Some sources including Marca have said that the RB18 was 4kg lighter at Belgium and weighed in at 802kg and just 4kg over the minimum allowed weight of 798kg. So there's been speculation as to how that was possible since it was understood to be 8kg over the minimum weight. Any news on how that was made possible aside from the speculation of the new chassis? In 2021 Honda introduced the new ES that was lighter than the previous so perhaps there were other weight savings made aside from chassis itself.
ispano6
153
Re: Red Bull RB18
from the-race:
Looks like the "Belgium" floor (Perez's) has elements of the Hungary and UK floor. The Hungary floor has the raised vertical blade edge.
French GP floor does not have the vertical blade edge:
Re: Red Bull RB18
Good spot. I never noticed the vertical edge to that part of the floor that appeared in Hungary
Here is a good photo showing the changes made at spa, especially those made to the sidepods
Source: F1i/Nicolas Carpenters
Re: Red Bull RB18
ispano6 wrote:
31 Aug 2022, 22:00
31 Aug 2022, 14:11
I'm guessing the weight reduction just comes from their natural weight reduction program that's been kicking in every few races for a drop of just under 5kg. Imola, Barcelona, France and Spa I guess. Then the light chassis might be the final weight update for the season? I think the weight limit would already be reached if not for the updates they've been making raising the weight again; Merc are having a similar problem I think
chrisc90
Re: Red Bull RB18
Is that a small rear floor stay there? Never noticed that on the RB before.
ispano6
153
Re: Red Bull RB18
01 Sep 2022, 00:04
Actually it looks the French GP that they introduced it but wasn't paired with the cutout/flap until Belgium.
Re: Red Bull RB18
chrisc90 wrote:
01 Sep 2022, 00:36
Appeared in Baku and has been there since. my guess is they didnt put one there sooner is to hide that the rear floor stiffness made as much a difference as it does
Re: Red Bull RB18
01 Sep 2022, 00:45
chrisc90 wrote:
01 Sep 2022, 00:36
My theory: Originally, floor stays were not legal so RB will have designed a floor that didn't require it. When floor stays became legal, they could lighten the floor layup by relying on the floor stay for stiffness. Alpine did the same thing. They started the season without the stay and then built a light weight floor that utilized the stay.
A lion must kill its prey.
vorticism
323
Re: Red Bull RB18
Makes sense. I think the floor stays as delegated were a last minute addition; as wires or thin rods they aren't ideal f.e. they have little to no compressive strength. They will help with floor deflection but not necessarily with flutter since that can still occur based on the tensile load fluctuating. Floor spars/beams/joists gave RB an edge from the beginning imo.
𓄀
Re: Red Bull RB18
Reprofiled high df rear wing for Zandvoort in the transition to vertical section. Looks like they trimmed some of the df compared to Barcelona/Monaco
* Was mistaken, wing level was used at Canada already
Cassius
Cassius
Re: Red Bull RB18
01 Sep 2022, 12:53
https://i.imgur.com/MJTHYVR.jpg
Did they not use this wing in Canada already?
Re: Red Bull RB18
Cassius wrote:
01 Sep 2022, 12:58
01 Sep 2022, 12:53
you're right! i thought they went med downforce at canada but was wrong
Maybe this is just their max df wing now, or they don't want to use the barcelona wing here
CaribouBread
CaribouBread
101
Re: Red Bull RB18
Image from AMuS/Tobi Gruner
All teams will be running bigger mirrors on Friday apparently, not a fan of the look to be quite honest. Maybe its time to move to digital cameras instead of mirrors.
Re: Red Bull RB18
CaribouBread wrote:
01 Sep 2022, 13:06
https://pbs.twimg.com/media/FbkJlyhXkAE ... ame=medium
Fortunately, Grüner is mistaken. Those covers have been used all season by RB in the garage to protect the mirror. Even if they are planning to trial larger mirrors, that's not an example of how they will look. Maybe there are the real, larger mirrors beneath the cover however
Here's the same mirror cover used at Hungary:
dxpetrov
dxpetrov
-7
Re: Red Bull RB18
This wing looks smaller than in Canada. This is not max df rear wing for sure though!
