Williams FW31 aero-mech development in 2009
bar555
bar555
GP AUSTRALIA
Undergone changes from Launch and Winter testing time
1.Thinner and higher nose cone
2.Nose cone end hole
3.Undernose channel
4.Front wheel rim shields
5.Airbox side winglet
6. Different sidepod panels
7.Different mirrors
8.Reshaped sidepods
9.Smaller exhaust outlets
10.Rear brakes winglets
11.Rear wheel rim shields
12.Rear Wing
13.Differenty diffuser
14.Livery change
To my good friend Carlos
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
Re: Williams FW31 aero-mech development in 2009
FRONT WING - AUSTRALIA
1.2009 regulations command that the central part of the front wing (500mm width ) must consist of a single element and must also conform exactly to the thickness and chord specified by the FIA .
2.Vertical nose pillars
3.Low height vertical fence
4.Extra winglet with an endplate
5. The endplate curve outwards to direct air around the front wheels.
6.Τhe outer extremities are bending slightly upwards to create a gap between the wing profile and the ground in order to reduce the pitch sensitivity of the car at high speed
7.Vertical fence under the wing to better direct airflow
8. Horizontal extension of the endplates , reduces front wing’s pitch sensitivity
bar555
bar555
REAR WING - AUSTRALIA
Only minor changes occurred from Launch time such as the flap connecting elements ( double connections instead of the central one )
NOSE CONE - AUSTRALIA
Thinner , and higher nose cone end with taller nose connecting pillars
NOSE CONE END HOLE - AUSTRALIA
Honeycomb style inlet . Hexagons provide the best structural design with the optimum available inlet surface
bar555
bar555
NOSE CONE CAMERA WINGLETS - AUSTRALIA
There is a winglet attached on either side of the nose cone, able to house a camera . During winter testing those winglets were randomly used .
SIDEPOD PANELS - AUSTRALIA
EXHAUSTS - AUSTRALIA
bar555
bar555
NOSECONE SPLITTER - AUSTRALIA
A short of venture channel is created under the nosecone which helps to increase air speed towards the lower part of the car .
MIRRORS - AUSTRALIA
The mirror’s mounting is now positioned lower and is much flatter , so as to be capable of guiding airflow towards the radiators inlets and the rear of the car
bar555
bar555
DIFFUSER - AUSTRALIA
Australia
Double Decker Diffuser
1.Double air deflectors
2.Vertical fence
3.Three channels
4.Central channel
5.Second upper central channel
6.The rear wing’s endplates are connected with the diffuser via flat vertical fences
Portimao January testing
1.Inclined profile with a vertical fence
2.Two channels
3.Central channel
4.Second upper central channel
bar555
bar555
FRONT WHEEL RIM SHIELDS - AUSTRALIA
REAR WHEEL RIM SHIELDS - AUSTRALIA
Williams developed further the complicated rear wheel rim shields presented by Toyota TF108 last year . The shield , made of carbon , is consisted of small identical aerofoils which allow hot air to escape from the wheel .
REAR BRAKES - AUSTRALIA
1.Double inlet , the large one for cooling the brake disc and the other smaller one for cooling the braking system itself .
2.Winglets
bar555
bar555
REAR LIGHT
Image Image
AIRBOX CAMERA WINGLETS - AUSTRALIA
During winter testing the side winglet was not always used
bar555
bar555
GP MALAYSIA
Undergone changes from Australia
1.Different front wing’s endplates
FRONT WING - MALAYSIA
REAR WING - MALAYSIA
NOSE CONE END HOLE - MALAYSIA
No change
SIDEPOD PANELS - MALAYSIA
bar555
bar555
EXHAUSTS - MALAYSIA
AIRBOX CAMERA WINGLETS - MALAYSIA
DIFFUSER - MALAYSIA
FRONT BRAKES - MALAYSIA
REAR BRAKES - MALAYSIA
bar555
bar555
GP CHINA
No changes
FRONT WING - CHINA
REAR WING - CHINA
NOSE CAMERA WINGLETS - CHINA
bar555
bar555
BARGEBOARDS - CHINA
Very low bargeboards compared to other teams designs
SIDEPOD PANELS - CHINA
No change
EXHAUSTS - CHINA
DIFFUSER - CHINA
bar555
bar555
GP BAHRAIN
1.Different style front wings for Rosberg and Nakajima
2.New longer rear wing’s endplates only for Rosberg
FRONT WING - BAHRAIN
REAR WING - BAHRAIN
New longer endplates only for Rosberg
bar555
bar555
NOSE CONE END HOLE - BAHRAIN
No change
EXHAUSTS - BAHRAIN
DIFFUSER - BAHRAIN
The new longer endplates , only for Rosberg , come down to meet the outer walls of the diffuser. In doing this they have slightly reduced the total width of the diffuser's side channels
bar555
bar555
GP SPAIN
1.Rosberg had his mirrors placed away from the cockpit zone
2.Larger sidepod panels
3.Nakajima used the new rear wing’s longer endplates
4.Hell energy drink sponsorship
5.New front wing’s endplates for Nakajima
FRONT WING - SPAIN
REAR WING - SPAIN
