AMuS - Andreas Haupt
Nice pic of the Ferrari engine from this season
Another good photo of the PU
johnny comelately
johnny comelately
110
If this Chronos stuff is not completely fanciful, it may be that the compressor ingress is reversed and the end plate is shaft bearing support. Guessing you people may have already figured this out, bit slow here.
The claim is a 2 kg weight reduction in the vee located water intercooler with more efficiency
DutchPanther
johnny comelately wrote:
12 Sep 2022, 23:35
https://images-wixmp-ed30a86b8c4ca88777 ... 6HWW-Yxa_c
I mean, I don't know about the rest of the F 175 but, that turbo design is just wrong.
I think the turbo is a radial entry, axial exit type turbo to a SABER type inter cooler, which itself is a axial entry radial exit type of intercooler.
How hard can it be? ~Jeremious Clarksonious
aleks_ader
90
No there is no such compressor u talking about. No matter on witch position it is. They just designed its entry and exit housing around conventional radial compressor.
Clubman1d
Clubman1d
ringo wrote:
11 Aug 2022, 02:54
Clubman1d wrote:
10 Aug 2022, 18:43
I don't believe it's a special compressor.
The setup must be something like, turbine, mgu-h, compressor, intercooler.
The compressor has only one exit that comes out the top turns to the front of the car and into the intercooler.
Are they still allowed variable intake runners?
Yes, based on what I have seen of the other engines.
I believe the compressor can be in the V. But why would it be so small?
I though the teams were moving away from small diameter compressors?
It seems Ferrari has very good response and low down torque.. but could this be because of the compressor size?
But how do they benefit to get peak power without a compromise.
It mustn't be inside the V, I imagine it like the Mercedes compressor, like part of the front engine cover.
It's IMHO the same setup as Mercedes but with a very different intercooler.
Drift4794
Drift4794
Great comparison of the four engine manufacturers. The comparison of the RB and Ferrari power units is particularly interesting.
https://www.formulapassion.it/opinioni/ ... 34419.html
Use DeepL to translate.
Clubman1d
Clubman1d
Why does the intercooler have an exterior heat shield in the center? Proof that the hot air coming from the compressor impacts the "back" of the IC before exiting the IC to the airbox?
You can even see the color diference from earlier pictures.
johnny comelately
johnny comelately
110
Drift4794 wrote:
24 Sep 2022, 13:41
The problem is there is little insight into how the energy is being deployed. This would provide clues as to whether Ferrari clipping at the end is actually a disadvantage, or whether it's simply because of a different deployment strategy.
It's explained by drag. The top speed is not a good placd to measure engine power. Too much aero effect dominate.
07 Oct 2022, 14:04
A drop in the speed at the end of the straight isn't explained by drag. It's explained by a reduction of power, typically from the MGU-K.
08 Oct 2022, 02:18
07 Oct 2022, 14:04
Higher drag eats more energy from the battery.
08 Oct 2022, 03:18
08 Oct 2022, 02:18
07 Oct 2022, 14:04
The amount of time for which you can deploy that 120Kw can be predicted without knowing how much drag you are carrying. It's only a function of the state of charge of the energy store and the output power of the MGU-K.
