Hi all new poster here and hopefully there is someone who can help me with a problem.
I race superkarts (http://spearmotorsports.com/superkart.aspx contians some nice pictures if you have no idea what one is) and I have a minor problem which I wonder if an f1 style chimney could fix.
The real problem is all my aerodynamic books do not contain information regarding chimneys and the web seems to lack an in-depth explanation to what actually is going on and how they achieve the desired effect.
If anyone could point me to a resource or provide a simple diagram showing rough principles (shapes angles etc ) that would be really benificial.
The possible application of the chimney is to help the airflow through the radiator. At the moment there is no ducting on the other side of the radiator at all which isnt really condusive to efficient flow. There is no room to fully duct the radiator but as an experiment I want to seal it off and use a vertical chimney to see if it improves flow. before doing anything I need to know how these things work
Thanks for any help in advance
