Absence of a certain statement does not prove the contrary of that statement.
That isn’t true. The fia said that the ‘notional’ tax credit was incorrectly applied. Notional means theoretical. There is no confirmation that this was a valid claim or even one that was at all possible.mwillems wrote: ↑02 Nov 2022, 14:43They did get the tax break. The FIA say they didn't "apply it correctly". Which means either the amount was wrong, or it was costed to the wrong type of expense or that it was done in the wrong period.
As an example of how the dates can come into play, it is possible they applied for the tax break in June 2021 and that the break should therefore apply to the 21 Cost Cap Financial Year, even if they received the tax break in February 22.
Or it is totally feasible that the error was that they applied it to an expense that was Cost Cap exempt, when it should have been applied within the cost cap.
Of course I doubt that since any team that spies an extra 1.8m to spend will find a way to apply it within the cap. So I suspect they tried to make it apply to this year.
But given that they had the chance to do a dry run, and didn't, and that they had the chance to engage directly with the FIA, and didn't, then this can be classed as gross negligence at best.
Unless I am very mistaking, the 'create and advance for the field, not just for your business' does not mean that is must be published, it does not need to be 'open source'.SiLo wrote: ↑02 Nov 2022, 17:36This is exactly what I was getting at. How can RB categorically say whatever they are developing is not just for their business? .....henry wrote: ↑02 Nov 2022, 16:37
The criteria
Advances in the field
Your project must aim to create an advance in the overall field, not just for your business. This means an advance cannot just be an existing technology that has been used for the first time in your sector.
Show that a professional in the field could not work this out
You should explain why a professional could not easily work out your advance.
I wonder what non-obvious advance in what field RB claimed they had made that isn’t just for their business?
Struggling to see what they are doing that is new, especially when there are so many regulations within which they have to build a car?
They didn't deliberately do anything as can be seen in the FIA's report
No it doesn't. It's a tax term and this has been explained on here many times.bonjon1979 wrote: ↑02 Nov 2022, 17:43That isn’t true. The fia said that the ‘notional’ tax credit was incorrectly applied. Notional means theoretical. There is no confirmation that this was a valid claim or even one that was at all possible.mwillems wrote: ↑02 Nov 2022, 14:43They did get the tax break. The FIA say they didn't "apply it correctly". Which means either the amount was wrong, or it was costed to the wrong type of expense or that it was done in the wrong period.
So to be clear, the tax credit did not exist in actuality at the time of filing and was incorrectly applied.
It's not cheating if you intentionally break a rule and accept the penalty for it.
HypocriteTimW wrote: ↑02 Nov 2022, 20:06It's not cheating if you intentionally break a rule and accept the penalty for it.
"They developed this new vortex generator to modify the airflow and increase downforce."SiLo wrote: ↑02 Nov 2022, 18:48Struggling to see what they are doing that is new, especially when there are so many regulations within which they have to build a car?
The lack of other teams commenting on this issue means we don't have much visibility of how applicable it is to any team in the paddock. It might be that all the teams get this pretty much every year.
It's not cheating if you do it publicly and in full knowledge of the whole paddock and the FIA et al and in accordance with the rules laid down. Hiding an engine allocation breach would be cheating - changing an engine and saying "we are within the engine allocation limit". I guess that's the correct analogy here.TimW wrote: ↑02 Nov 2022, 20:06It's not cheating if you intentionally break a rule and accept the penalty for it.
Red Bull hid nothing and did not intentionally go over the cap, Mercedes hid nothing and intentionally went over the cap.MadMax wrote: ↑02 Nov 2022, 20:27It's not cheating if you do it publicly and in full knowledge of the whole paddock and the FIA et al and in accordance with the rules laid down. Hiding an engine allocation breach would be cheating - changing an engine and saying "we are within the engine allocation limit". I guess that's the correct analogy here.
