2022 São Paulo Grand Prix - Interlagos, Nov 11 - 13
basti313
basti313
Re: 2022 São Paulo Grand Prix - Interlagos, Nov 11 - 13
Spacepace wrote:
10 Nov 2022, 02:56
10 Nov 2022, 02:32
f1jcw wrote:
10 Nov 2022, 02:30
Surprised more hasn’t being said. Teams agreed to it to help, then was double crossed.
Explain more where the double crossing was?
He never said they double crossed anyone. Only that Red Bull played it off well. Regulation power plays encouraged by Red Bull that they knew was to there advantage. They'd know what the engine was putting out on the dyno. Nothing wrong with maneuvering themselves like that. Red Bull are well put together team
Besides the reading issues...you really think they knew also what the others had on the dyno? And you know how much the real difference is now? Is it really that big that one could aim for this huge difference in 2020???
Don`t russel the hamster!
Images from AMuS (if no source on image) and Fabrega
Everyone using the medium df wing with gurney except Aston Martin and Mercedes (who unsurprisingly use the high downforce wing). Compared to other races, seems to be more convergence on best setup approach
SirBastianVettel
SirBastianVettel
11 Nov 2022, 15:05
Will be a quiet weekend on this forum then I guess..
search
Sainz will get a new (although similar spec, I guess?) engine at least. Will be interesting to see if Ferrari will try to run it at max power for a change - it doesn't need to last long anyway.
11 Nov 2022, 15:05
As expected :lol:
A lion must kill its prey.
Max has a ton of understeer. Seems the setup they arrived with isn't ideal
Only +5 so far. Duchessa said earlier this weekend another +5 is possible (maybe for a turbo?) but so far their plan is only the ICE
11 Nov 2022, 17:38
I think it's just the hard tires not having much grip on a green track.
Apparently Alpha Tauri, Haas, Aston Martin all have had to increase cooling because it's quite warm today.
Rain is due at quali time ish
Perez leading with a laptime set halfway into the session...
Soft tyres are holding on for multiple quali sims and barely any deg in RB's long run on the soft. Max started his long run in the low 1.16s and finished on the mid 1.16s with about 15 laps done on that set
Thinking Pirelli are a step too hard this weekend
