The rules only allow for 120kW (161hp) from the hybrid unit. Unless they can turn that DC power into 200hp at the motor output?Hoffman900 wrote: ↑16 Nov 2022, 03:19* 800bhp from 1.6L (then another ~200hp or so from the hybrid unit)
You would have to ask Pat Symmonds.wuzak wrote: ↑17 Nov 2022, 02:57The rules only allow for 120kW (161hp) from the hybrid unit. Unless they can turn that DC power into 200hp at the motor output?Hoffman900 wrote: ↑16 Nov 2022, 03:19* 800bhp from 1.6L (then another ~200hp or so from the hybrid unit)
A physical impossibility. Power does not care about gearboxes because energy is conserved (or rather, you can only lose it through friction. You cannot gain it beyond what is released from the ES).wuzak wrote: ↑17 Nov 2022, 02:57The rules only allow for 120kW (161hp) from the hybrid unit. Unless they can turn that DC power into 200hp at the motor output?Hoffman900 wrote: ↑16 Nov 2022, 03:19* 800bhp from 1.6L (then another ~200hp or so from the hybrid unit)
Hoffman900 wrote: ↑17 Nov 2022, 02:58You would have to ask Pat Symmonds.wuzak wrote: ↑17 Nov 2022, 02:57The rules only allow for 120kW (161hp) from the hybrid unit. Unless they can turn that DC power into 200hp at the motor output?Hoffman900 wrote: ↑16 Nov 2022, 03:19* 800bhp from 1.6L (then another ~200hp or so from the hybrid unit)
How often are the wastegates open?saviour stivala wrote: ↑17 Nov 2022, 12:42In electric supercharging mode (when waste-gate/s are open – no backpressure) the ‘H’ is in motor mode and not only not recovering but it is sharing ES power with ‘K’.
My guess is they are a lot like what was described for the Audi DTM engine strategy wise (RET Issue 137). They run a fixed boost level (rules restricted) with varying lambda. They found it is faster around a race track this way due to the ability to be back at full power after a shift more quickly than varying boost and a having fixed lambda (like most people do). This was worth 0.17” at Hockenheim. They have graphs showing power % / boost / etc (with the x-axis being time ) showing the improvements during / after a shift. Over this 1" window, average power was 40hp more with constant boost / varying lamda vs. varying boost / constant lambda. They realized more time from driver confidence / driveability.johnny comelately wrote: ↑17 Nov 2022, 14:40How often are the wastegates open?saviour stivala wrote: ↑17 Nov 2022, 12:42In electric supercharging mode (when waste-gate/s are open – no backpressure) the ‘H’ is in motor mode and not only not recovering but it is sharing ES power with ‘K’.
Hardly at all is my thought.
Fair pointsaviour stivala wrote: ↑17 Nov 2022, 18:49‘’How often are the waste-gate/s open’’. Turbocharger waste-gate/s in formula one are not used to control boost pressure. They are used so as exhaust gases bypass turbine when the compressor is in electric supercharging mode.
Which other racing series other than F1 uses an MGU-H attached to turbocharger?.
Porsche 919 had an MGU-Hsaviour stivala wrote: ↑17 Nov 2022, 18:49‘’How often are the waste-gate/s open’’. Turbocharger waste-gate/s in formula one are not used to control boost pressure. They are used so as exhaust gases bypass turbine when the compressor is in electric supercharging mode.
But not connected to a compressor - it was only driven by a turbine, which was driven by the exhaust from the main turbo.AR3-GP wrote: ↑18 Nov 2022, 04:18Porsche 919 had an MGU-Hsaviour stivala wrote: ↑17 Nov 2022, 18:49‘’How often are the waste-gate/s open’’. Turbocharger waste-gate/s in formula one are not used to control boost pressure. They are used so as exhaust gases bypass turbine when the compressor is in electric supercharging mode.
Tommy Cookers wrote: ↑17 Nov 2022, 11:19
PU peak power ....
800 (say) hp conventionally + 160 hp from K motor action + 40 hp in electric supercharge (no 'backpressure')
EDITED for clarity
that's 800 hp mechanical power + 40 hp mechanical power ('air motor' action - no backpressure) + 160 hp K motoring
If the MGUH was driving the turbo to a speed where the backpressure is eliminated, would the wastegates need to be open at all?saviour stivala wrote: ↑17 Nov 2022, 12:42In electric supercharging mode (when waste-gate/s are open – no backpressure) the ‘H’ is in motor mode and not only not recovering but it is sharing ES power with ‘K’.
