Venturiation wrote: ↑08 Jan 2023, 12:48Do you think that’s what they are referring to when articles say that mercedes will have better fuel ,and they also say work has been done to the gearbox for W14AR3-GP wrote: ↑07 Jan 2023, 00:38Improving the friction modifying and thermal conductance properties of a gearbox oil can reduce friction in the gearbox and/or allow a smaller, lighter gearbox cooler, which also has less air resistance.
Improved coolant can allow higher operating temperature and smaller radiator. This has several positive knock-on effects for performance. Higher operating temperature allows for a smaller water cooler which weighs less, and has less air resistance. Higher operating temperature seems to make the combustion cycle more efficient as well. Something to do with the energy that is lost due to the temp difference between the working gases, and the engine block.
In years past, it was claimed that some were experimenting with burning coolant for combustion....but that's for another thread
I think the "new fuel" rumor that was reported was nonsense. Fuel is frozen.
The work on the gearbox is likely moreso related to the location of the gearbox, attachment points of the control arms, and the rear suspension mechanisms and geometry. Not the oil.
Furthermore, while I expressed that in theory coolants and gearbox oils can offer a development playground, realistically the current specifications of coolants and gearbox oils are highly developed and there is very little if not anything left to optimize in these lubricants. I don't expect appreciable gains from one season to the next at this late stage.
That's quite unlike a brand new fuel which would like see big improvement if teams were granted another homologation date. However they are not. It's frozen.
