The render (pictures posted in the thread already) has the front wing that they brought at the end of 2022 so I'm inclined to think the render is an accurate representation of what the c43 will be
Wavy/jagged yeah. Maybe using some of the same effect that made those shark tooth diffusers effective under the previous aero regs
Its a feature, serrated edges prevent trailing edge separation and spanwise flow - while also slighlty reducing frontal area and thus reduce drag.organic wrote: ↑07 Feb 2023, 11:52https://i.imgur.com/UgtJpIT.jpeg
Wavy BW trailing edge
It's not just an image artifact, it's either artistic license by whoever was making the render or it's a feature
Bargeboards are back on the floorOwen.C93 wrote: ↑07 Feb 2023, 11:59Did the FIA increase the floor edge height and accidentally move it into a less restricted zone? Or was this design just not worth it when you could instead get the floor edge to scrape the floor last year I wonder.
Also I don't think these are renders, look like studio shots as there's a few things like misaligned seatbelts, panel sinkages and uneven carbon weave. Hard to be 100% sure.
