A huge advantage is in compromises between engine and chassis/body. Customers get the compromise made between the engine department and car department of the supplier.
Only small things probably, but I bet they add up
Adapt to what? Someone else's preferred PU layout for their preferred aero layout?Emag wrote: ↑12 Feb 2023, 11:29Now, the power units are frozen, it's gonna be the same PU layout until 2026. That nullifies the packaging advantage because it gives customers time to adapt.Ground Effect wrote: ↑12 Feb 2023, 08:36I honestly can't believe guys on here are minimising the technical advantage of a works team. Has it been narrowed over the years ? Yes, but in specific areas only. Same PU, same mappings, same software, same fuel etc. Why did McLaren suggest when they signed with Renault that they could possibly be involved in the direction of PU layout? Of course Renault downplayed this suggestion, because it would be giving away a considerable advantage.
I suppose. But the Renault engine was so unreliable in 2022, I don't see how Renault power in 2022 would have helped Red Bull's chances given Mercedes and Ferrari refuse to supply Red Bull. [Not that the Ferrari was that reliable either.]Emag wrote: ↑12 Feb 2023, 11:29So yeah, works teams still got an advantage. But I also disagree with the premise of RedBull being unable to win last year if they weren't a works team. They had such a dominant car that I don't really think the advantages they got for not being a customer team were critical.
Like I said McLaren have to supply their own exhaust. You don't get that with tge PU. You can route that anywhere you want within the performance requirements that Merc give you.AR3-GP wrote: ↑12 Feb 2023, 04:40too much stuff is being overlooked.
Look at the exhaust routing of the Mercedes PU. It has been designed for their aero package. Look at the compressor inlets. It has been designed for the W13 intercooler configuration. The engine tuning, the pressure waves in the intake system, it's all tuned around the Mercedes intake system.
What benefit is any of this to Mclaren? A power unit is not just some plug and play bit of kit. contrary to what others have said, they are not all "shaped the same"Why are people in denial? As if there is no tangible benefit in a game of splitting hairs.
Only the exhaust pipe behind the turbine is free. The exhaust system also includes the pipework between the cylinder head exhaust ports, and the turbine inlet. The medusa. That is what I'm referring to. This is defined by the manufacturer.diffuser wrote: ↑12 Feb 2023, 15:10Like I said McLaren have to supply their own exhaust. You don't get that with tge PU. You can route that anywhere you want within the performance requirements that Merc give you.AR3-GP wrote: ↑12 Feb 2023, 04:40too much stuff is being overlooked.
Same with the intercooler, it is a rad. McLaren supply their own. Plus alot of the other stuff you mention was set like that 4 or 5 years ago or more. It isn't stuff that changes year to year.
There are always compromises, even when you're the works. Generally the choices Merc made for themselves probably work for everyone else.AR3-GP wrote: ↑12 Feb 2023, 15:14Only the exhaust pipe behind the turbine is free. The exhaust system also includes the pipework between the cylinder head exhaust ports, and the turbine inlet. The medusa. That is what I'm referring to. This is defined by the manufacturer.diffuser wrote: ↑12 Feb 2023, 15:10Like I said McLaren have to supply their own exhaust. You don't get that with tge PU. You can route that anywhere you want within the performance requirements that Merc give you.AR3-GP wrote: ↑12 Feb 2023, 04:40too much stuff is being overlooked.
Also, I never said that Mercedes supply the intercooler or radiator.
This stuff is not trivial like you would like to believe. Mercedes already made the compromise between the power unit output level, it's geometry, and its cooling requirements. Location of oil pumps, fuel pumps, harnesses etc etc.
and 2022 is a ringing endorsement.diffuser wrote: ↑12 Feb 2023, 15:27There are always compromises, even when you're the works. Generally the choices Merc made for themselves probably work for everyone else.AR3-GP wrote: ↑12 Feb 2023, 15:14Only the exhaust pipe behind the turbine is free. The exhaust system also includes the pipework between the cylinder head exhaust ports, and the turbine inlet. The medusa. That is what I'm referring to. This is defined by the manufacturer.diffuser wrote: ↑12 Feb 2023, 15:10
Dont be daft mate
AR3-GP wrote: ↑12 Feb 2023, 15:44and 2022 is a ringing endorsement.diffuser wrote: ↑12 Feb 2023, 15:27There are always compromises, even when you're the works. Generally the choices Merc made for themselves probably work for everyone else.AR3-GP wrote: ↑12 Feb 2023, 15:14
Both scenarios are possible but I don't know how we can make more than a random guess from where we are.genarro wrote: ↑12 Feb 2023, 18:38Dont be daft mate
Maybe broaden their department yes.. But the people in the team are top notch... The infrastructure is where performance is lost.. We have heard many times that the old windtunnel has a blind spot and the other infrastructure as well... We will get there, just have a little patience.
I thought the engine freeze took effect in 2022?
I have no idea if you are correct or not but it should be noted that there was a fuel change before the 2022 season.
Nah.. red bull has a old wind tunnel but still better than McLaren.. the infrastructure excuse is oldgenarro wrote: ↑12 Feb 2023, 18:38Dont be daft mate
Red Bull has a wind tunnel on site, specifically setup for race cars, which has been updated yearly.
