ValeVida46 wrote: ↑27 Apr 2023, 17:30
AR3-GP wrote: ↑27 Apr 2023, 16:37
I never said that the teams have the power to tell the FIA what to inspect in a random inspection. I only said it's possible for ongoing discussions and whispers to influence the direction of the FIA, even though their processes are supposed to be independent.
No, what you actually said was "you can see that some teams have started their fishing expedition". Seems to me that you are conflating random checks to be nefarious in Red Bull's case but for everyone else it's legit.
They checked the Merc rear wing at the first race of the season (among other things).
I never said the selection process wasn't random or that another team directed the FIA to choose the Red Bull. When I said "fishing expedition" I meant that teams are always in discussion with tombazi and his technical team about how they can do a better job policing certain areas of the regulations and sometimes the FIA can react subtly in the way they do their inspection procedures (literally changing load test), overtly (impounding the Ferrari PU after a race in 2019) or even issuing technical directives as a result of other teams proving that some part of the regulations is exploitable. This happened with floors last year and engines in 2019 and 2020/2021
Also, you cannot submit a technical protest for a mechanism for which you do not understand or have proof of it's existence. The Ferrari was never protested in 2019. No car was protested over flexing floors in 2022. All that happened was a silent technical directive introduction.
If a team suspects cheating from a rival they can offer evidence and a rule which it contravenes. There is no requirement in the protest to "understand".
It is the FIA who decide on case by case basis what is acceptable means of protest.
As specified by the DAS protest by Red Bull.
https://www.formula1.com/en/latest/arti ... 1Vh8U.html
So the assumptions you're making in this are:
The FIA does checks under the influence of whispers and ongoing discussions.
Some teams went fishing.
The FIA waited for the random check to check an item they were tipped off by the fishing teams.
There is a difference between observing what one perceives as a regulation violation, and simply gawking at the performance of another car, as grounds for a protest. The driver was pushing the steering wheel and the toe angle was changing. They were not protesting "how it worked" and they did not need to know "how it worked". All they did was say that the driver was operating a device that made the toe angle change and that it was on camera and questioned whether it was a moveable aero device. That's essentially how protest are done and it's why no one could protest the Ferrari in 2019. There wasn't any "evidence" upon which to protest beyond "their car accelerates faster than mine". They didn't have mechanics on video putting tin foil around the fuel flow meter
Most teams start from a default position of thinking their rival is doing something suspicious to get their speed even when they don't know what that is. Some teams have pointed to the Red Bull's very low ride heights and top speeds being linked to their suspension system. You can't submit a catch all protest suggesting a car is "illegal" without any context as to in what way it is. Running low ride height and having top speed are not grounds for protest. There is no minimum rideheight in the regulations and there is no speed limit outside of the pitlane. That's the difference between protesting DAS,and protesting the idea of a Red Bull running with low ground clearance.
You realise, the FIA can simply tell Red Bull to haul their car to the stewards without any need for protest, or random checks? So there is no need to wait for Red Bulls number to come up to do this supposed inspection.
I mean the next extension to this would be the FIA doctored the random process to inspect the Red Bull.
I'd also just say I have no issue with your opinion, say what you like. But when you're adding level upon level of assumptions, Occams razor comes in handy.
Sometimes a random check can just be that.
It's true that the FIA can haul any car out on suspicion of "doing something untoward" but this is not actually practical for many reasons. It's is only in extreme cases where we see this. If I'm not mistaken the fuel system (or was it the entire power unit) of the Ferrari was "impounded" in Brazil 2019? This carries great political consequences because naturally if you don't actually know "what" is illegal, and you don't find anything, it is politically damaging to haul cars off willy nilly for "deeper inspection" especially with the way journalist are so quick to cast cheating aspersions. You have to be realistic. It has to be a pretty deep concern for the FIA to announce that they are singling out a specific car and this came to fruition in 2019 with Ferrari.
As for everything else, I don't believe the FIA suspects that Red Bull are doing anything suspicious more likely because if there is anything suspicious, it is beyond their imagination. However, I do believe that other teams think Red Bull are doing something suspicious because other teams are far better at understanding how to engineer regulations exploits. This is how it has always been. Teams always know better than the FIA how to abuse the rules. I'm sure Tombazi has gotten whispers from other teams that are vague and don't really cut a clear picture of what issue they have. These kinds of things can have an influence on how the FIA acts.
With all the rumors of silver bullets, the RB's performance, and discussion surrounding ride heights, it's not really a surprise that the FIA ended up looking at the suspension system of the REd Bull. They aren't going to haul the red bull out individually because they don't actually have any idea what they are looking for and you have to have apretty clear idea otherwise you run into the isssue of politics and PR that I mentioned earlier. So when the RB is selected at random, it's a silver platter opportunity to go fishing without having any of the baggage of hauling them out in public and embarassing yourself when you don't find anything.
The random draw gave them the RB on a silver platter. Now they FIa got to announce that they looked deeply into the suspension and didn't find anything. This serves many purposes. Can you imagine if they inspected the steering system and the wiring looms instead?
