Ferrari SF23
sbrillo
sbrillo
Re: Ferrari SF23
Looks that Ferrari brought a new floor. Do we have some photos? The one that Sainz using right now looks the same spec of that one used yesterday. Do you confirm?
F1NAC
173
Re: Ferrari SF23
sbrillo wrote:
24 Feb 2023, 10:07
Don't have still shots yet but it seems old one yeah.
SmallSoldier
SmallSoldier
488
Re: Ferrari SF23
Front Suspension box:
Halo detail:
Vía: AMUS
FDD
FDD
83
Re: Ferrari SF23
not clear picture but it looks like they are running different floor today
Re: Ferrari SF23
Any photos with flow vis on top of diffuser? Sainz ran with a big splash some time ago
JK_
JK_
Re: Ferrari SF23
From today
SmallSoldier
SmallSoldier
488
Re: Ferrari SF23
Vanja #66 wrote:
24 Feb 2023, 11:58
This is from yesterday:
Vía: Albert Fabrega
Vía: @The_Pocisk
sbrillo
sbrillo
Re: Ferrari SF23
yes, it's different
Re: Ferrari SF23
Re: Ferrari SF23
GrrG
86
Re: Ferrari SF23
Ferrari: here are the double baskets in the front corner
GrrG
86
Re: Ferrari SF23
Re: Ferrari SF23
Please use edit button to avoid making 5 posts in 5 minutes!
LostInTranslation
LostInTranslation
Re: Ferrari SF23
Two questions, in terms of aerodynamics, for those who understand more than me.
1) Don't you think that those minimal fins between the second and third upper element of the Ferrari FW are able to give a minimum advantage in terms of outwash, but at the same time they hook, bind, the third element making it less free to flex? We lack a front low camera to judge. But it’s my first impression.
2) The double central pylon against the single one in the rear wing support? By eye, I think that the single support benefits a greater weakness of the wing, especially in the lateral parts, producing a greater advantage at high speeds, in the sense that, being weaker, it can be flexible and produce less air resistance and a lower drag at maximum speeds.
Re: Ferrari SF23
Point 1) keeping fixed attachment between elements ensures proper gap, as well as transmition of loads. Loads transmit downforce where needed, but also flex the wing, reducing drag on straights :wink:
Point 2) It's usually a trade off between FIA strength requirements and desire to allow wing bending to reduce angle and drag at speed. For lateral stability two pylons are better than one. For aero losses, two thinner pylons are better than one thicker. It's not really a detrimental thing, but I feel teams would like to keep as much lateral stability as possible, to reduce stress on beam wings and keep them light. So overall, Ferrari solution is more than OK.
