Ferrari SF23
Xyz22
Xyz22
124
Re: Ferrari SF23
03 Mar 2023, 14:00
already removed from the car :? i guess it will need modification in order to run it
It lasted a bit longer this time.
Schippke
Schippke
Re: Ferrari SF23
Would be interesting to see if it was shaking that much last week, prior to the upper flap breaking... unless it effectively broke straight away...
Xyz22
Xyz22
124
Re: Ferrari SF23
More material for Vanja :D
Venturiation
Venturiation
102
Re: Ferrari SF23
ferrari ride height
Re: Ferrari SF23
Venturiation wrote:
03 Mar 2023, 13:55
rear wing shaking alot
This single pylon wing is giving a lot of trouble.
gordonthegun
254
Re: Ferrari SF23
Fede90 wrote:
03 Mar 2023, 13:49
https://i.postimg.cc/YSv79wpw/Senza-titolo.jpg
it seems simpler than floor tested before
It was already in the tests but there should be another one with a more jagged edge for this race.
I think it's this:
gordonthegun
254
Re: Ferrari SF23
03 Mar 2023, 13:36
New rear-wing is massively wobbly on Leclerc's car :?
This is the greatness of Ferrari.
Here in Italy we know it well.
ryaan2904
ryaan2904
36
Re: Ferrari SF23
Xyz22 wrote:
03 Mar 2023, 14:07
Is that separation towards the bottom of the upper wing element?
CFD Eyes of Sauron
Re: Ferrari SF23
Beam wing stifness is not aligned with single pylon vs double pylon design. They could maybe stiffen them in the garage if they have the tools, but it could be a not very reliable fix for the race. Flow vis is ok, the flap is too shallow to expect any separation.
Re: Ferrari SF23
Ferrari might've tipped their hand, everybody is gonna be looking extra careful at this wing to see if it flexes down with speed.
The exaggerated side movement is unintended, still this kind of fragility probably has a reason.
gordonthegun
254
Re: Ferrari SF23
Sevach wrote:
03 Mar 2023, 15:18
If it flexed too much it would be immediately noted and banned by the FIA.
This is the usual Ferrari that in some cases seems to be a "GP2 engine".
Re: Ferrari SF23
It's neither a gp2 engine or another problem. They are chasing every gram and it's clear. It's better to go over the limit and need to add some weight, than have a part that's too heavy but you have no idea where to lose some weight...
Andi76
Andi76
451
Re: Ferrari SF23
Ferrari won't use this rear wing at Bahrain because of problems.
https://scuderiafans.com/ferrari-postpo ... ahrain-gp/
CMSMJ1
CMSMJ1
Re: Ferrari SF23
Con Inglese? En Anglais? Auf Englisch?
Can we have that translated? Grazie!
IMPERATOR REX ANGLORUM
gordonthegun
254
Re: Ferrari SF23
Vanja #66 wrote:
03 Mar 2023, 15:31
This wing was already in testing and broke, now, after a week, you put it again on the car and it swings like a bell and you can't use it for the race.
That wing was very important because it gave a little more downforce and now you can't test with that setup.
A top team can't do that.
Worth noting that Ferrari is the only top team (really? :? ) to still have two pylons for the rear wing.
