2023 car comparison thread
Venturiation
Venturiation
101
Re: 2023 car comparison thread
01 Mar 2023, 21:25
Hopefully this isn't repeating content that is already here too much.
Nextgen auto 📸 compiled by @LuisFeF1 on twitter
https://i.imgur.com/vU0Ngwb.jpeg
https://i.imgur.com/rTo5ypS.jpeg
https://i.imgur.com/bc25kjC.jpeg
https://i.imgur.com/T4GAECX.jpeg
Are there pictures or video like this at turn 13 to see how low the cars are and if they are porpoising?
F1Krof
95
This one is quite interesting:
Wroom wroom
F1Krof
95
This was brilliant demonstration of what causes porpoising, how the floor works and how the seal the floors.
Wroom wroom
mzso
mzso
66
F1Krof wrote:
10 Mar 2023, 14:42
https://www.youtube.com/watch?v=Ks0cRGq7x1Q
Really? Because he didn't even produce visible oscillations, which I expected...
BAKf1
BAKf1
Can somebody explain to me why the regs wouldn’t permit a manufacturer from minimizing the floors downforce (using the floor more like a barge board) and instead creates more of the downforce overbody such that the car acts like the faster 2021 version?
AMR22 vs AMR23 vs RB18 vs RB19 brake caliper.
It seems that both RB and AMR brought this "pins and needles" brake caliper design for 2023. It didn't feature on either team's cars in 2022. What an interesting coincidence.
Old cars for reference:
232
The AMR22 has fins/ribs on its caliper if you looks closely. So the engineers did have the concept of extended surfaces in mind but used studs instead in 2023. Possibly because of design changes with the caliper and resulting differences with airflow and maybe even for weight purposes.
In fact the amr23 is a mix of fins and studs.
Andi76
Andi76
446
BAKf1 wrote:
11 Mar 2023, 18:11
In short, because the rules are very restrictive on the use of "overbody"-aerodynamic devices. It would be impossible to generate the overbody downforce that would be necessary to even begin to approach the downforce of the underbody. However, it is important to note that F1 cars have been generating most of their downforce through the underbody for many years. Already in 2004 it was 45%. In 2009 it was around 50%, and the percentage has been rising steadily. Underbody downforce produces less drag than overbody downforce, so it is always more effective to seek more downforce from the underbody.
Juzh
161
Andi76 wrote:
12 Mar 2023, 20:03
BAKf1 wrote:
11 Mar 2023, 18:11
In mid 2000s underbody rules were much less restrictive, higher diffusers and so on. Then they continuously got more and more nerfed. 2014-2016 floors were very simplistic and shallow.
Andi76
Andi76
446
Juzh wrote:
12 Mar 2023, 21:32
Andi76 wrote:
12 Mar 2023, 20:03
BAKf1 wrote:
11 Mar 2023, 18:11
That's right, but the designers always found ways to improve underfloor performance and even in these years 45% of the downforce was produced by the underfloor. It was always the component that provided the most downforce for the minimum drag, just as it provided over 50% of the total downforce from 2017 and far more today.
Andi76
Andi76
446
Great comparison of the Red Bull and the AM that shows these cars really have a lot of similarities. Wheelsbase, Driver Position, sidepod positioning etc. all seems to be practically idendtical or pretty close:
Andi76 wrote:
17 Mar 2023, 22:34
https://postimages.org/
I'm not sure why your pictures are always posted in smallest resolution, but this one would be much better in full size :)
vorticism
323
Use the "Direct Link" option and use the [img] tags here.
𓄀
mzso
mzso
66
Vanja #66 wrote:
17 Mar 2023, 22:44
Andi76 wrote:
17 Mar 2023, 22:34
This may be the source:
mzso wrote:
18 Mar 2023, 01:21
Vanja #66 wrote:
17 Mar 2023, 22:44
Andi76 wrote:
17 Mar 2023, 22:34
https://pbs.twimg.com/media/Frbn8jiWwAE ... name=large
Is this from Jeddah? It's interesting how much more cooling openings the Aston has. The bathtub probably means they can't quite get the cooling exhaust out to the back of the car efficiently.
