Ferrari SF23
Vinlarr89
Vinlarr89
Re: Ferrari SF23
Andi76 wrote:
01 Jun 2023, 21:09
LostInTranslation wrote:
01 Jun 2023, 20:48
New bellies?
No, not good! Same bugs as always.
My implicit and innate wind tunnel tells me at first glance that there is no forward elongation of the lower lip of the side air intakes such as to bring the attachment to the height of the central pin of the halo (see RB).
Why do I say this?
I say this because a more pronounced lower lip forward sends the same air above the radiators but gathers much more to send under the CoG (center of gravity), gaining many tenths of a second in terms of downforce.
Not only that, a good chunk of the lower bellies could be cut in terms of aerodynamics and the sliding flow of the air which would point towards a precise center creating less resistance to penetration.
I hope I'm wrong, but I don't expect anything new in Barcelona in terms of results.
Wow - all the F1 teams must be after you and you must be making millions if you can see all this with your naked eyes. Ferrari - here is one who is a hundred times better than Newey! Get him! Quickly! Come on, man.
But seriously - you are aware that the Ferrari 2017 invented this "underbite"? And also the person is still there who came up with it? So they know quite well what advantages and disadvantages this has and why to do or not to do.
Yep they also have to work within all the constraints in terms of the cooling setup and the SIS. It’s not as straightforward as copy and pasting RB sidepods onto the car.
alleyoop
alleyoop
Re: Ferrari SF23
John Noble call the new sidepods "Red Bull-style".
Maybe I need more photos to understand
Andi76
Andi76
422
Re: Ferrari SF23
alleyoop wrote:
01 Jun 2023, 21:28
However. Much more. And edited ones.
FDD
FDD
78
Re: Ferrari SF23
2 vortex generators, I think this is new
FDD
FDD
78
Re: Ferrari SF23
Andi76 wrote:
01 Jun 2023, 21:30
alleyoop wrote:
01 Jun 2023, 21:28
Yes, different. I can say more closely to F1-75, pretty vertical with channel like undercut, with upper side also quite different.
falonso81
Re: Ferrari SF23
These sidepods seem to be quite a bit thinner than the old ones. Maybe i am wrong but the sis bulg seems bigger now. The rear bodywork also appears more sculpted.
Re: Ferrari SF23
falonso81 wrote:
01 Jun 2023, 22:33
SIS bulge is bigger because the undercut is deeper, but the SIS has not moved.
AMG.Tzan
42
Re: Ferrari SF23
alleyoop wrote:
01 Jun 2023, 21:28
I wouldn’t call them Red Bull style but more like Ferrari refining their last year concept!
And I’m saying this because Red Bull’s side pods start a bit more in front and higher than Ferrari’s and also their undercut starts a lot further behind than Ferrari! What I also see in Ferrari’s upgrade is that the big undercut behind the side pods is gone and the side pods are again wider and straighter like last year but now they connect to the kick in the floor like almost all teams!
Curious to see if there’s a tight slide like Aston Martin’s somewhere at the back of these side pods…
Re: Ferrari SF23
AMG.Tzan wrote:
01 Jun 2023, 23:09
alleyoop wrote:
01 Jun 2023, 21:28
I'm almost positive that there is a groove on the inboard side of the sidepod. The connection to the louvers on the engine cover doesn't make sense otherwise.
miguelalvesreis
miguelalvesreis
Re: Ferrari SF23
AMG.Tzan wrote:
01 Jun 2023, 23:09
alleyoop wrote:
01 Jun 2023, 21:28
Even the colour of the top of the sidepod is strange. One can see the line separating on the bath tub border
Enviado do meu RMX3241 através do Tapatalk
AMG.Tzan
42
Re: Ferrari SF23
01 Jun 2023, 23:14
AMG.Tzan wrote:
01 Jun 2023, 23:09
alleyoop wrote:
01 Jun 2023, 21:28
Exactly that!
There seems to be a downward trend right there at the louvers but from this angle the groove looks to be much slimmer than Aston Martin’s!
Also curious to understand what the highly inclined floor aero bit in front of the rear tire does!
Re: Ferrari SF23
AMG.Tzan wrote:
02 Jun 2023, 00:06
01 Jun 2023, 23:14
AMG.Tzan wrote:
01 Jun 2023, 23:09
I think the kick at the rear corner of the floor was added at start of 2022 as well. My view is that it could be a change that is aimed to maximize expansion (and therefore downforce generation) at the cost of less air funneled between the diffuser and rear tyre to manage the rear tyre squirt
Re: Ferrari SF23
I can't make heads of the sidepod top yet, it seems like instead of a bathtub it appears to have a narrow downwash channel on the inside and flat outsides.
Hopefully we get some good top angle pics as the car comes out of the pits.
Also not sure if the team has fully given up on it's coke bottle design, though some area appears to have been sacrificed.
F1Krof
94
Re: Ferrari SF23
Looks interesting :shock:
Wroom wroom
scuderiabrandon
102
Re: Ferrari SF23
Deep narrow gulley as I predicited earlier
PC: @berrageiz (twitter)
