scuderiabrandon wrote: ↑04 Jun 2023, 11:33
Andres125sx wrote: ↑04 Jun 2023, 11:33
scuderiabrandon wrote: ↑04 Jun 2023, 11:27
Leclerc the only driver on the grid to say something isn't right with his car, have data to back his comments up and
be still slandered. Crazy.
What data?
it was the post before your intial comments, did you just come on a technical forum to chat ---?
He complained about the right rear of the car not being okay during qualifying, here the data shows him losing big chunks of time only through left hand corners? I highly doubt he forgot how to turn left...
Just in case you didn´t notice, almost all demanding corners in Montmelo are right hand, so right tires tend to get too cold. Lecrerc suffered from this. Sainz didn´t.
But if you disagree, please enlighten me, what problem with the car will make only one side of the car underperform while the other side performs at high level?
Some driver being unable to put the tires on temperature is not a problem of the car. Will you say the same when that problem to trasnfer heat to the tires will benefit him degradation wise? Or then you will claim how good is Lecrerc because he managed to make longer stints than any othe driver?
It´s a driver style characteristic, with cold temperatures it is a problem, with high temperatures it is a benefit, as simple as that
