Hoffman900 wrote: ↑09 Jun 2023, 04:47
gruntguru wrote: ↑09 Jun 2023, 04:45
That paper speaks of choking in the port throat - not across the valve seat.
It's the same when you tried to use 30 year old graphs to argue with a then AVL combustion engineer now Ilmor.
. . . and with that comment your level of understanding neatly slips several rungs in my estimation.
A combustion engineer who argued that increasing turbo boost would dramatically increase pumping losses.
Also that best TE occurs at stoich????
Clearly you can get a job at AVL or Ilmor as a "combustion engineer" without knowing much beyond how stuff burns.
Perhaps you would like to re-open that old thread and argue his case? Personally I think he has reconsidered. Perhaps he eventually raised the points with some knowledgeable colleagues?
