That was the terrain not grass launching him. We're not saying a trough of grass, just a flat grass strip.
As for your low friction surface suggestion, I've had similar thought about using sheet or plate metal. Might have the same effect. Rubber build up might defeat the purpose. Knurling of ribbing on its surface would reduce contact patch area. Low profile metal strips perpendicular to the direction of travel might act like slides.
