Andrea Stella [McLaren]: "Spa-Francorchamps is normally mentioned as one of the high speed tracks, but in reality, the higher speed corners are turn 10, which is flat out in qualifying."
"There is a lot of lap time in corner one, which is 80km/h, corner 8, which is 100km/h and the last chicane, which is 90km/h. So, I don’t want to repeat myself, but I go with some care in these three corners, we see that we loose time."
"It will be how rapidly you adapt your car to the demand of the track [because it's a Sprint weekend]. Spa is a very demanding track in terms of your understanding, for instance, your ride heights. Eau Rouge, you can’t run too low because otherwise you’ll have problems under the car. So, how rapidly you can adapt your car will influence the weekends performance."
@JunaidSamodien_
