New Videos
mx_tifoso
mx_tifoso
Re: New Videos
Sebastien Vettel won the Lorenzo Bandini trophy for his 2008 season. Here is a video from Eurosport from that day in Italy.
:arrow: Vettel wins trophy - Eurosport
overdrayv
Re: New Videos
mx_tifoso
mx_tifoso
Re: New Videos
Callum
Re: New Videos
[youtube]http://www.youtube.com/watch?v=yb8SU4TR ... re=related[/youtube]
skip to two minutes, its not strictly f1.. but i thought it was quite cool.
its a slow motion video of a top fuel dragster puncture.
roost89
roost89
Re: New Videos
Callum wrote: skip to two minutes, its not strictly f1.. but i thought it was quite cool.
Some nice shots in that video. Isn't that just tyre deformation due to the power going through the tyre? I remember them talking about it on CSI (I know it's a drama series but some of it may be true)
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
Callum
Re: New Videos
hm, thats true, i was looking at the engine's right hand bank and looking at the flames, i thought maybe that was the tyre falling apart. Maybe it IS just deformation.
Ciro Pabón
106
Re: New Videos
Well, yes, I think the same thing: I have a couple of pictures of drag tyres undergoing the same deformation, no puncture, just the large torque twisting the tyre wall.
Ciro
stl0
stl0
Re: New Videos
Those guys use tires with incredibly soft sidewalls and virtually no air in them. When the tire begins rotating faster centrifugal force makes it taller. The "flatter" tire gives a larger contact patch at rest for the start, and the taller tire gives taller gearing under speed.
If you ever go to see these things run bring earplugs, and it might be a good idea to have some penicilin handy.
Birel99
Re: New Videos
MX, Is that you in the onboard?
Ciro Pabón
106
Re: New Videos
I believe stl0 is right. The tyre also "cushions" the forward torque on the car, serving as some kind of "second clutch".
This "clutch" avoids to "bog down" the engine (that is, the rpm go down) when the tyres receive the initial "shock": you might go out of your ideal torque band.
On the other hand you don't want tyrewalls so flexible that they warp "too much", because they cause "tyre shake" (I think that's the english name): you get heavy oscillations after the initial "twisting".
Tyreshake can be so bad that objects fixed in the cockpit might become loose and even drivers have to use teeth protectors (mouthguards).
The tyres twist like, well... like rubber.
Ciro
WhiteBlue
92
Re: New Videos
Ray
Re: New Videos
Ciro Pabón wrote:I believe stl0 is right. The tyre also "cushions" the forward torque on the car, serving as some kind of "second clutch".
The tires are there to absorb the very high torque, in the high thousands of pounds. I've heard the Top Fuel and Funny Cars make 7-8,000 HP and at least that in torque, don't know if it's true but I've heard well over 10,000 foot pounds. The tires deform to give the maximum contact patch, and they don't get the clutch fully locked until after 300 feet into a run, sometimes farther depending on track temp and oildowns etc. The clutch in those cars slip for most of the run. Tire shake is very very bad. Eric Medlin was killed by tire shake that the team he drove for, John Force Racing, had NEVER seen it that bad. It literally shook him so hard it killed him.
ISLAMATRON
Re: New Videos
WhiteBlue wrote:[youtube]http://www.youtube.com/watch?v=6z0hjQryQGs[/youtube]
is that oil or fuel they are pouring in... I know those turbos used to burn some nasty stuff... and that would be preety thin for engine oil... anyone know what viscosity oil they run these days?
The le mans corvettes this year were running zero weight mobil 1 oils
Edit... ha it says right on the container.... Engine oil, plus earlier it shows a hose that looks like it could be fueling the car
modbaraban
modbaraban
Re: New Videos
Superleague Formula. Just another junior single seater series. The name doesn't sound very exciting.
But listen to this :shock:
[youtube]http://www.youtube.com/watch?v=mv_QfhAlGB8[/youtube]
ISLAMATRON
Re: New Videos
There is a reason that even Ferrari abandoned the V12 in 1981 and then again 1996... while it may seem to sound great, it is not the best solution for the given engineering problem.... There are plenty of unattractive women with great voices... put the V12 in that same category.
Even today, given a 2.4L displacement nobody would choose to run a V12.
