PlatinumZealot wrote: ↑30 Jul 2023, 19:49
The RB19 indeed was saving the front left in Eau-Rouge and putting it to better use in other parts of the lap. I would say we saw a glimpse of "weakness" when the car ran in mixed conditions. It's DRS is also the best, but not strong enough to immediatley break a DRS train. Takes a few laps of the car in front's tyre to wear down first and then the RB19 makes its move.
Is that really weakness though? Or is that being clever and understanding the tyre loadings/heat increases etc through corners early on and saving some tyre for later on in the lap?
Or do you mean a weakness when the conditions were changing between dry and wet? I wouldn't have classed a little twitch through eau rouge a weakness if thats the case. We would need to compare laptimes coming into the wetter period and exiting it to see how the others were doing time wise.
Personally, I dont think the RB19 needs to wait until the car infronts tyres have deteriorated enough by defending. Lewis was in a DRS train with Leclerc. Once Lewis dropped out of the 1 second window, Max was able to get past. The RB19 is good, but it is not 'slippery' enough to overtake the car infront whilst it is using DRS on a low drag wing. (Lewis was running one of the slimmer Rear wings of the weekend?)
What could be a interesting thing to look at is the laps Lewis was behind chares (who had no DRS) and Lewis who had DRS. What was the speed differentials between them as I never really saw Lewis manage to mount an attack, or even a look up the side of Charles along the Kemmel Straight. Even if Charles was dumping a load of battery, i'd of expected Lewis to be able to sneak a look own the side.
