Have you ever worked on a project based job?TFSA wrote: ↑07 Aug 2023, 12:05Sorry for being blunt, but the real world doesn't work like that. People can't just go at 120% at their job in exchange for downtime, especially not if it's a job that requires thinking (for physical labor you might get some benefit). You can't just think at 120% speed. And similarly, trying to work 120% power at a computer isn't gonna be more efficient. Rather, it's more likely to introduce mistakes and you have to spend time finding and correcting those mistakes.basti313 wrote:It works a bit differently. They do not "learn" from these projects. You use the nonsense projects to get more efficiency.
Example:
- You could put one engineer on the aero of the F1 car at 40h per week.
- You could put two engineers on the aero of the F1 car at 20h each and the other 20h they do some boat or supercar without pressure.
In the cost cap you get two engineers for the cost of one. They can work 120% in the 4h per day on the F1 project and drink coffee and recreate in the other 4h. Generally you can only count 90% productive hours...so one would try to put non productive hours to the other project. So the second option is in the end much more efficient and gives you a broader range of smart engineers, thus, ideas.
This is why ALL top teams have their side projects. So it is nonsense to discuss cars like the Valkyrie or AMG One. This does not matter and the tech is simply different. It is just the possibility to pay double loan with some non-profit projects to keep more engineers busy.
Now, you could get your team more relaxation/downtime with what you're proposing at the other project, and that can have some benefits, but that's still gonna lose you efficiency. Why?
- Because most tasks require coordination and exchange of knowledge, and you'll now have two people spending time having to get each other up to speed every time they swap, rather than having one person focused on the task. Also swapping can introduce mistakes if not all relevant knowledge is imparted in the swap.
- Because people differ in expertise and skill, you'll now have the person with the most expertise giving half his workload to someone with less expertise, compared to simply hiring the more experienced person and having him work full time on his task.
What you're suggesting may sound great in theory, but it doesn't work on practice. You'll be paying two wages instead of one (even if only half goes on the cost cap), and you won't be getting your moneys worth. You're gonna be worse off.
Of course it makes a huge difference which pressure each project has. And of course it makes 120% if you still think about the relevant project once you work on the other project.
Furthermore it is proven, that an employee on a 30h job is much more efficient than one on a 40h job. So if they just fill the pipeline with recreational jobs it has the same effect.
