As per this video the air guns work at 450 psi, 16000 rpm, 3000-4000 lbs-ft
10s of running is practically nothing. Don't invent stuff.JordanMugen wrote: ↑29 Aug 2023, 07:05Was the double wheel de-attachment in the F2 feature race, due to the electric impact wrenches being overstressed with doing a double-stacked pitstop?
Little relevance to Vesti.
How? You make them as fast as you want them... Besides it's trivial to make something like airguns slower.
Actually the video states they go up to 600 lbs·ft on the wheelnut.FW17 wrote: ↑29 Aug 2023, 08:08As per this video the air guns work at 450 psi, 16000 rpm, 3000-4000 lbs-ft
https://m.youtube.com/watch?v=xOJydyfPQ ... hlZWwgZ3Vu
When ive been to silverstone you can hear them testing the guns from the campsite.
You are completely right about the power. But where is the need for this speed? If they mandate a spec electric gun...then it is a fair game for everyone.
Can you make them as fast as you want on a battery ? I thought about a battery based setup as we wanted to get rid of the wires.
I think F1TV described that at the Dutch GP where there is no space for a extra garage…. It effectively makes the pitlane longer and it plays out differently when the race is running.
I do not think it plays a role....simple comparison between Canada (lowest pitlane loss) vs. Monza (highest pitlane loss):
Why do you want to make them faster?DDopey wrote: ↑31 Aug 2023, 13:31Can you make them as fast as you want on a battery ? I thought about a battery based setup as we wanted to get rid of the wires.
Cost doesn't matter under cost cap.basti313 wrote: ↑31 Aug 2023, 16:39I do not think it plays a role....simple comparison between Canada (lowest pitlane loss) vs. Monza (highest pitlane loss):
In Monza you see often different strategies. Last year nearly 50:50.
In Canada where the low time loss would support different strategies...you see 90% similar strategies.
You would in the best case get a wheel gun sponsor who sends tested and certified wheel guns to every team....stock as they are to save cost.
